I need help to install and config ssl certificate
Hello !
I run this comand
sudo certbot --nginx -d siraterp.pro -d www.siraterp.pro
Account registered.
Requesting a certificate for siraterp.pro and www.siraterp.pro
An unexpected error occurred:
No such authorization
Domain: siraterp.pro
Type: dns
Detail: no valid A records found for siraterp.pro; no valid AAAA records found for siraterp.pro
This is quite self-explanatory I'd say.
While you have an A RR configured in the DNS zone for the www subdomain, no such record exists to configure an IP address for the apex domain siraterp.pro. See e.g. siraterp.pro | DNSViz.
