How to fix ssl not install in nginx
My domain is: viptoolhub.com
I ran this command: sudo certbot --nginx -d example.com -d viptoolhub.com
Requesting a certificate for viptoolhub.com and www.viptoolhub.com
Domain: www.viptoolhub.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.viptoolhub.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.viptoolhub.com - check that a DNS record exists for this domain
bhatti@vip-tool-hub:~$ ^C
My web server is (i don't know):
The operating system my web server runs on is (ubantu):
My hosting provider, if applicable, is: digitalocean
I can login to a root shell on my machine (using new username):
this is web version Ubuntu 24.04 (LTS) x64
First and foremost, before trying to issue TLS certificates you should get you website in working order.
Your apex domain currently has 4 A and 3 AAAA records:
$ dig +short viptoolhub.com
172.64.52.210
172.64.53.21
172.64.49.209
128.199.9.216
$ dig +short aaaa viptoolhub.com
2606:4700:52::ac40:31d1
2606:4700:52::ac40:34d2
2606:4700:5a::ac40:3515
The IP starting with 128 is owned by digitalocean. All of the others are owned by cloudflare. Since your domain isn't managed by cf: you and your visitors will experience issues, I'd advise getting rid of cloudflare IPs.
As for the particular error you're experiencing: there are no A or AAAA records for your www subdomain. Either add them, or don't attempt getting a certificate for this subdomain.
you you tell me how to fix
