I need help in ssl certificate
I have a server with a DirectAdmin control panel. I tried to automatically renew the SSL certificate license, but it’s not allowing me to do so and displays the following error:
error: one or more domains had a problem:
: acme: error: 503 :: POST :: https://acme-v02.api.letsencrypt.org/acme/authz-v3/429665071227 :: urn:ietf:params:acme:error:rateLimited :: Service busy; retry later.
exit status 1
I need urgent help
Hello @globalsolution, welcome to the Let's Encrypt community. :slightly_smiling_face:
I've moved this post from Issuance Tech to Help
Had you opened this thread in the Help section, you should have been provided with a questionnaire. In any case, all the answers to this questionnaire are required:
Thank you for assisting us in helping YOU!
You may want to upgrade the DirectAdmin control panel for the graceful handling of that non-fatal error condition. If the latest version has no fix, then you may want to open an issue at the appropriate support channel of DirectAdmin.
For details of this transient error condition please check:
https://community.letsencrypt.org/t/new-service-busy-responses-beginning-during-high-load
Yep, thanks @bruncsak -- we've had some abnormal network conditions so far today leading to more traffic hitting one of our datacenters than usual. It should be calming down, but a retry should be all you need.
My domain is: www.readline.co.il
I ran this command: I didn't run any command because it's built into the control panel of my server
It produced this output: error: one or more domains had a problem:
exit status 1
The operating system my web server runs on is (include version): centos Latest version
My hosting provider, if applicable, is: Not relevant
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): DIRECT ADMIN Latest version
