zeJanit
September 4, 2024, 11:12pm
1
The domain is whenreadingishard.com
crt.sh | 14429918002
I setup a lightsail instance, messed up. got angry and deleted it then reinstall it. then I relizxed my error as far as ssl's are concerned. I can prove I own the domain anyway you want. how can i revoke that SSL so i can install another ssl on the new lightsail?
zeJanit
September 4, 2024, 11:13pm
2
I no longer have any access to the cert, pem or private key. its gone i deleted it
Hi @zeJanit ,
That doesn’t seem like one of the reasons to revoke a certificate.
When a certificate is no longer safe to use, you should revoke it. This can happen for a few different reasons. For instance, you might accidentally share the private key on a public website; hackers might copy the private key off of your servers; or...
zeJanit
September 4, 2024, 11:18pm
4
it states i can revoke it by proving I own the domain...
zeJanit
September 4, 2024, 11:19pm
5
how do I find the right dns values so i can revoke it?
Why must the certificate be revoked?
What is the reason?
zeJanit
September 4, 2024, 11:21pm
7
I deleted the instance without backing up the SSL files, if i can just add dns records and reinstall on the new lightsail that will work. I assumed I needed to revoke?
Most likely not. You have not lost the domain and the private key was destroyed (and not under someone else control).
zeJanit
September 4, 2024, 11:24pm
9
so that means I can not longer use Lets encrypt? or how do i reinstall? when i try it fails assuming I have the other server running, which i do not.
No, just get a new certificate issued.
rg305
September 4, 2024, 11:26pm
11
No; It only means you can no longer use that cert.
You are still eligible to issue more certs for that same name.
zeJanit:
how do i reinstall?
Reinstall what?
zeJanit:
when i try it fails
What fails?
What exactly did you try and what exactly did the failure message say?
zeJanit
September 4, 2024, 11:27pm
12
I'm attempting to install lets encrypt the same way on the new lightsail but it fails.
zeJanit
September 4, 2024, 11:28pm
13
omg, your not gonig to believe how stupid I am....i forgot to change the DNS..
What ACME client are you using,
or what ACME client does lightsail use?
