I run /root/certbot-auto renew and got this message
Domain: template.kassakaappi.net
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
b7e6b8d9c0277fce72a8c3b84581f201.37da990a836d654af7c42bb7cf74927b.acme.invalid
from 178.63.3.78:443. Received 1 certificate(s), first certificate
had names “dummy,
e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”
Domain: static.kassakaappi.net
Requested
ab0e191e7bade73b45252cfa83915630.ac91cc1fb4228cb2271596f1dac208f1.acme.invalid
had names "dummy,
Domain: www.kassakaappi.net
Requested
7a4b2900b8685757e00dfefccf68c08a.c0bb47b671037e5a65bb2357ffd58013.acme.invalid
had names “dummy,
Domain: vanha.kassakaappi.net
Requested
f9864816cbfa3c1beb7da93d66f7a43e.65490c2e985e892a0e72a35300784ab0.acme.invalid
had names “dummy,
Domain: kassakaappi.net
Requested
bc1baad292edd083b67252fb95b90daa.60a480f1d7c461a3c0000393d3cc2185.acme.invalid
had names “dummy,
Domain: hiekkalaatikko.kassakaappi.net
Requested
1f29e1e5c7a1085471cb7e950e085c04.e569ef25f2cf62adb7d67750428e54c1.acme.invalid
had names “dummy,
and got this error. Where is the problem?
Attempting to renew cert from /etc/letsencrypt/renewal/www.kassakaappi.net.conf produced an unexpected error: Failed authorization procedure. hiekkalaatikko.kassakaappi.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested cf7085d17b138cb4b4972b25344622df.a3db745b0ede3e06ecab49789ebe56c3.acme.invalid from 178.63.3.78:443. Received 1 certificate(s), first certificate had names “dummy, e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”, static.kassakaappi.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 257d91f41123d2444308e3bd19d8aa3c.1ea08c67cfc3684a1c7e097a22dd7b66.acme.invalid from 178.63.3.78:443. Received 1 certificate(s), first certificate had names “dummy, e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”, kassakaappi.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 1e73b3c647c1b61fce161c984978fdeb.b8c18824d3fbd64548c275c1efd7229e.acme.invalid from 178.63.3.78:443. Received 1 certificate(s), first certificate had names “dummy, e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”, vanha.kassakaappi.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested d8e019e65451393596e830c1b7b01823.fb0cde3b6af0c9fc6ea8915d1da70b42.acme.invalid from 178.63.3.78:443. Received 1 certificate(s), first certificate had names “dummy, e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”, www.kassakaappi.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 0fa3b3120edd8632f69a881e41f2fa4e.3ee971d2ae26f42c80b56ebe04a2dd05.acme.invalid from 178.63.3.78:443. Received 1 certificate(s), first certificate had names “dummy, e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”, template.kassakaappi.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested df8f83958147d0a6cc89ac17fbad546f.b6c9725155cb9c6d69221be09bc13868.acme.invalid from 178.63.3.78:443. Received 1 certificate(s), first certificate had names “dummy, e238032ae4e9ce14d8ffdad3157843d1.b863de3f08166ae82f3d56a218f488e0.acme.invalid”. Skipping
