Trouble with expiration
My domain is: kasdivi.com
I try to access my mail and apple mail says the certificate has expired on 7/08/2022
i run sudo certbot renew
Processing /usr/local/etc/letsencrypt/renewal/kasdivi.com.conf
Cert not yet due for renewal
The following certificates are not due for renewal yet:
/usr/local/etc/letsencrypt/live/kasdivi.com/fullchain.pem expires on 2022-09-09 (skipped)
No renewals were attempted.
apache 2.24.51
freebsd 13
no
1.13.0
Which mail server are you running?
How did you last load the cert into it?
In short: The web server is using the latest cert; But the email service is still using the previous one.
[which expired on July 8]
I'm guessing here. LE updates the certs... 001, 002, etc. The mail server... whatever it is is looking at an outdated cert?
It is important to know which mail server is running. Whatever it is it would be beneficial to script the distribution of the cert(s) so the mail server is always up to date.
My 2 cents
Thanks for the quick responses. I am running Postfix 3.6,3. and Dovecot 2.3.17. I think that the mail service interface with Dovecit
Half way there...
Maintain certificate on server with certbot. Specify the resulting certificate (/usr/local/etc/letsencrypt/live/kasdivi.com/fullchain.pem ) in the Dovecot SS Configuration,
I was able to force apple mail to trust the expired Certificate. My experience has been apple and some browsers don't play well with letsemcrypt. Email seem happy again even with what it thinks to be an expired certificate
Then you may only need to restart/reload Dovecot.
[after each certificate renewal]
It IS an expired cert being served.
thing was only the Iphone was upset. But I will restart dovecot. That make more sense
Ok I restarted dovecot. The correct certificate shows up. but Apple mail doesn't trust. Like i said Appel doesn't seem to like letsencrypt. Will tinker to see what I can do.. Now definately an Apple Mal Problem
Then you might need to switch to chains OR switch to another (free) CA provider.
It is weird No problem with my desktop. Letsencrypt works fine for my website (except with Brave). IN the end issue appears apple iPhone apple mail.. I will probably swap mail apps out first. They make a great OS for desktop and a POS for tablets and phones
Also, try using the "short chain".
short chain? Is that attached my phone to a short chain and throw it off a bridge?
ok did the usual apple mail phone fix .. delete the account and add it again . All good not a letsencrypt issue. Thanks again
