Is this good showing information? In Webmin System Information and I blocked out my URL hostname.
Or trying to install it with this command my show good info. ./letsencrypt-auto --verbose
I replace my URL with XXXX.XX in this verbose text of installing it. All so took out some repeating things to make post smaller.
root@ICS32:~/letsencrypt# ./letsencrypt-auto --verbose
Updating letsencrypt and virtual environment dependencies...
Requirement already up-to-date: setuptools in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: pip in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: letsencrypt in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: letsencrypt-apache in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: zope.interface in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: setuptools in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: python2-pythondialog>=3.2.2rc1 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: PyOpenSSL in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: requests in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: ConfigArgParse in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: parsedatetime in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: configobj in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: pytz in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: psutil>=2.1.0 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: six in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: cryptography>=0.7 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: zope.component in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: mock in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: acme==0.0.0.dev20151104 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: pyrfc3339 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt)
Requirement already up-to-date: python-augeas in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from letsencrypt-apache)
Requirement already up-to-date: idna>=2.0 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->letsencrypt)
Requirement already up-to-date: pyasn1>=0.1.8 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->letsencrypt)
Requirement already up-to-date: enum34 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->letsencrypt)
Requirement already up-to-date: ipaddress in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->letsencrypt)
Requirement already up-to-date: cffi>=1.1.0 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->letsencrypt)
Requirement already up-to-date: zope.event in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from zope.component->letsencrypt)
Requirement already up-to-date: funcsigs in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from mock->letsencrypt)
Requirement already up-to-date: pbr>=0.11 in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from mock->letsencrypt)
Requirement already up-to-date: ndg-httpsclient in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from acme==0.0.0.dev20151104->letsencrypt)
Requirement already up-to-date: werkzeug in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from acme==0.0.0.dev20151104->letsencrypt)
Requirement already up-to-date: pycparser in /media/256SSD/root/.local/share/letsencrypt/lib/python2.7/site-packages (from cffi>=1.1.0->cryptography>=0.7->letsencrypt)
Running with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt --verbose
lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x Saving debug log to /var/log/letsencrypt/letsencrypt.log x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x This is a PREVIEW RELEASE of a client application for the Let's x
x Encrypt certificate authority and other services using the ACME x
x protocol. The Let's Encrypt certificate authority is NOT YET ISSUING x
x CERTIFICATES TO THE PUBLIC. x
x x
x Until publicly-trusted certificates can be issued by Let's Encrypt, x
x this software CANNOT OBTAIN A PUBLICLY-TRUSTED CERTIFICATE FOR YOUR x
x WEB SERVER. You should only use this program if you are a developer x
x interested in experimenting with the ACME protocol or in helping to x
x improve this software. If you want to configure your web site with x
x HTTPS in the meantime, please obtain a certificate from a different x
x authority. x
x x
x For updates on the status of Let's Encrypt, please visit the Let's x
x Encrypt home page at https://letsencrypt.org/. x
x x
tqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqu
x x
x Which names would you like to activate HTTPS for? x
x lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk x
x x [*] XXXX.XX x x
x x x x
x x x x
x x x x
x x x x
x x x x
x x x x
x mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj x
x x
x x
x x
x x
x x
x x
x < OK > x
x Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x You have an existing certificate that contains exactly the same x
x domains you requested (ref: /etc/letsencrypt/renewal/XXXX.XX.conf) x
x x
x Do you want to renew and replace this certificate with a x
x newly-issued one? x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x Generating key (2048 bits): x
x /etc/letsencrypt/keys/0016_key-letsencrypt.pem x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x Creating CSR: /etc/letsencrypt/csr/0016_csr-letsencrypt.pem x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x Performing the following challenges: x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x dvsni challenge for XXXX.XX x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x Waiting for verification... x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x x
x Reporting to user: The following 'connection' errors were reported x
x by the server: x
x Domains: XXXX.XX x
x Error: The server could not connect to the client for DV x
x To fix these errors, please make sure that your domain name was x
x entered correctly and the DNS A record(s) for that domain x
x contain(s) the right IP address. Additionally, please check that x
x your computer has a publicly routable IP address and that no x
x firewalls are preventing the server from communicating with the x
x client. x
x by the server: x
x client. x
x Cleaning up challenges x
Failed authorization procedure. XXXX.XX (dvsni): connection :: The server could not connect to the client for DV :: Failed to connect to host for DVSNI challenge
- The following 'connection' errors were reported by the server:
Domains: XXXX.XX
client.
I hope this helps to know why it don't work and what to do to get it to work.
-Raymond Day
