I can't add ssl to aws ec2 for my doman in namecheap
My domain is: remgeeshop.com
I ran this command: sudo certbot certonly --webroot -w /home/ubuntu/ecommerce/root_files/ -d remgeeshop.com -d www.remgeeshop.com
Account registered.
Requesting a certificate for remgeeshop.com and www.remgeeshop.com
Domain: www.remgeeshop.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.remgeeshop.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.remgeeshop.com - check that a DNS record exists for this domain
Domain: remgeeshop.com
Detail: 3.128.89.255: Invalid response from http://remgeeshop.com/.well-known/acme-challenge/J71_UQIE55JPxJuKdurhqatdQXYhi4D2957h9JvwcZM: 404
The operating system my web server runs on is (include version): ubuntun pro
My hosting provider, if applicable, is: aws ec2
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): aws ec2 instance
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
These are two different errors. NXDOMAIN means you forgot to add dns records for your www. subdomain (you should add A and/or AAAA, same as @).
404 on the http-01 challenge means your webserver has some configuration issues or you told certbot the wrong webroot directory.
what it the webroot directory for because I am using django
Where does this come from?
Also, why are you using --webroot instead of --nginx?
Using webroot requires you to use the same directory as the root nginx directive for the proper server/location block.
-w /home/ubuntu/ecommerce/root_files/ this is the static files of my django website
okay okay I should use --nginx
if that works, yes. I don't know anything about your nginx configuration, and it can be, how do I put it... "messy," at the very least.
@chrispydev, if that had been the webroot expected it should have validated that name.
So... it must not be the correct webroot for that name.
I suspect that the vhost config only covers one of the two names and the default config is what is matched to this uncovered name.
We can be more certain when you show us the full nginx config, with:
nginx -T
Side note: Port 443 is presently closed.
$ nmap -Pn -p80,443 remgeeshop.com
Starting Nmap 7.94SVN ( https://nmap.org ) at 2023-12-23 13:22 PST
Nmap scan report for remgeeshop.com (3.128.89.255)
Host is up (0.081s latency).
rDNS record for 3.128.89.255: ec2-3-128-89-255.us-east-2.compute.amazonaws.com
PORT    STATE  SERVICE
80/tcp  open   http
443/tcp closed https
Nmap done: 1 IP address (1 host up) scanned in 0.13 seconds
And from around the world "Connection refused" for HTTPS - Permanent link to this check report
