HTTPS URL still not working after i run certbot certonly --webroot
Hi guys, anyone know why my webpage https is still not working even i have run “certbot certonly --webroot…” and returned “Congratulations! Your certificate and chain have been saved at…”
It still showing “Your connection is not secure…” when I visit using https://…
Please help anyone…appreciate…
The certonly options means certbot will only save the issued certificate to your servers disk (by default at the location /etc/letsencrypt/live/yoursite.tld/fullchain.pem.
With certonly, you yourself are responsible to install the certificate into your webserver.
I would suggest using the Mozilla SSL Configuration Generator to use the appropriate configuration for your webserver.
You will need to change:
/path/to/private/key to /etc/letsencrypt/live/yoursite.tld/privkey.pem
And either:
/path/to/signed_certificate --> /etc/letsencrypt/live/yoursite.tld/cert.pem ánd
/path/to/intermediate_certificate --> /etc/letsencrypt/live/yoursite.tld/chain.pem
or
/path/to/signed_certificate_followed_by_intermediate_certs --> /etc/letsencrypt/live/yoursite.tld/fullchain.pem
You might want to choose to disable the HSTS Enabled option on the generator, until you’re sure your HTTPS works perfectly.
Hmm…but the <VirtualHost *:443>… code where should I put? I cant locate the conf file…I quite confuse which conf actually my server is using…I found there is a default-ssl.conf also…
Well, that totally depends on the webserver used and how you configured the webserver initially…
