HTTPS to HTTP Redirection on Apache Means Site is Not Secure
My domain is: www.freshculture.me
My operating system is (include version): Ubuntu 14.04
My web server is (include version): Apache 2.4.7
My hosting provider, if applicable, is: Linode
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): NO
I have installed the SSL Certificate on my Server. However only the Homepage is https accesible. Any other internal page on the site is accessible only by http and not https.
Please let me know what am i doing wrong here.
Hi @pratiklohia,
All your site is being redirected from https to http:
$ curl -IkL https://www.freshculture.me
HTTP/1.1 302 Found
Date: Fri, 12 May 2017 15:07:18 GMT
Server: Apache/2.4.7 (Ubuntu)
X-Powered-By: PHP/5.5.9-1ubuntu4.14
Set-Cookie: adminhtml=m98l2r8audlttignstlf1evkh3; expires=Sat, 13-May-2017 15:07:18 GMT; Max-Age=86400; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Set-Cookie: adminhtml_cid=ksa0Eq6oP00w9NOt; expires=Sat, 13-May-2017 15:07:18 GMT; Max-Age=86400; path=/; domain=freshculture.me; secure
Location: http://www.freshculture.me/             <---- here is the redirect to http
Access-Control-Allow-Origin: *
Connection: close
HTTP/1.1 200 OK
Date: Fri, 12 May 2017 15:07:19 GMT
Set-Cookie: adminhtml=2q82anbq5kr5i1t0fiqob1pd34; expires=Sat, 13-May-2017 15:07:19 GMT; Max-Age=86400; path=/
Pragma: no-cache
X-Frame-Options: SAMEORIGIN
Fpc-Cache-Id: FPC_REQUEST_deae781df7b2b72d251221e4500d49aa
Connection: close
Maybe you have a redirect/rewrite rule on your apache... or in some .htaccess file.
Cheers,
sahsanu
Thanks Sahsanu.
I added the following in the etc/apache2/sites-enabled/000-default.conf
Redirect permanent / https://www.freshculture.me
But I get an error that the website is not redirecting properly.
@pratiklohia, if you already have a redirect from https to http and you add a new redirect from http to https you only get a neverending loop. As I said, you need to find where is the redirect, you should search for Redirect or RewriteRule directives inside your apache conf files or in any .htaccess you are using in your site.
Looked into the Server Config files… there are no rewrites there.
The only suspect the nwould have been .htaccess in the root folder of the Web App.
I am not able to clearly tell which of these directives could be doing the rewrite. Kindly assist.
workaround for HTTP authorization
in CGI environment
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
TRACE and TRACK HTTP methods disabled to prevent XSS attacks
RewriteCond %{REQUEST_METHOD} ^TRAC[EK]
RewriteRule .* - [L,R=405]
redirect for mobile user agents
#RewriteCond %{REQUEST_URI} !^/mobiledirectoryhere/.*$
#RewriteCond %{HTTP_USER_AGENT} "android|blackberry|ipad|iphone|ipod|iemobile|opera mobile|palmos|webos|googlebot-mobile" [NC]
#RewriteRule ^(.*)$ /mobiledirectoryhere/ [L,R=302]
always send 404 on missing files in these folders
RewriteCond %{REQUEST_URI} !^/(media|skin|js)/
never rewrite for existing files, directories and links
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !-l
rewrite everything else to index.php
RewriteRule .* index.php [L]
Hi @pratiklohia,
Those rules should not cause the redirection so I’m thinking that some php file is performing the redirect, maybe on index.php. Please, run the following grep command from the Document Root of your site:
grep -ri 'Location:' *
If it doesn’t provide any output, search for command header inside your php files.
grep -ri 'header' *
And show the output.
Next time, paste the text, select it and click on the icon </> so the output won’t be messed by the forum syntax.
Cheers,
sahsanu
