http works good
i just installed my let’s Encrypt and it gives my
on browser firfox This site can’t be reached
pmcegyptgroup.com refused to connect.
Try:
- Checking the connection
- Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
i check it by https://www.sslshopper.com/ssl-checker.html#hostname=https://pmcegyptgroup.com
the result was
No SSL certificates were found on pmcegyptgroup.com. Make sure that the name resolves to the correct server and that the SSL port (default is 443) is open on your server’s firewall.
i check my server firewall
root@vmi260129:~# ufw status
Status: inactive
root@vmi260129:~# ufw allow 443
Skipping adding existing rule
Skipping adding existing rule (v6)
root@vmi260129:~#
My domain is: https://pmcegyptgroup.com
I ran this command: apt install certbot ; certbot certonly --manual -d *.pmcegyptgroup.com.com -d pmcegyptgroup.com --agree-tos --no-bootstrap --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory
also i update configuration. file root@vmi260129:/etc/apache2/sites-available# nano default-ssl.conf
ServerName pmcegyptgroup.com
ServerAlias www.pmcegyptgroup.com
DocumentRoot /var/www/htmlDocumentRoot /var/www/www.pmcegyptgroup.com/html
<Directory /var/www/html>
Options -Indexes +FollowSymLinks
AllowOverride All
Order allow,deny
allow from all
ErrorLog ${APACHE_LOG_DIR}/mcegyptgroup.com-error.log
CustomLog ${APACHE_LOG_DIR}/mcegyptgroup.com-access.log combined
SSLCertificateFile /etc/letsencrypt/live/mcegyptgroup.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/pmcegyptgroup.com/privkey.pem
My web server is (include version): apache Apache/2.4.34
The operating system my web server runs on is (include version): ubuntu 18.04 ,
My hosting provider, if applicable, is: contabo
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): webmin 1.910
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.27.0-1
