It produced this output: I could complete the steps successfully
My web server is (include version): apache 2.4 (sudo yum install httpd)
The operating system my web server runs on is (include version): CentOS 7.8 2003
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.3.0
I was able to access my website using IP address and domain name before running certbot.
After running certbot successfully, I could not access the website using domain name.
I can still access it using IP address.
I used sudo certbot --apache
I selected Both domains: rignova.com and www.rignova.com
I chose: [2] Redirect
And, finally I got congratulations message.
Note: This is a new server and I have updated the DNS too.
I think you misunderstood the --rollback effect.
It will not remove the cert.
It will roll back the Apache config as it was just before the most recent certbot change.
In what way is it “not working”? What error message do you get?
For me, connecting to your site over HTTPS times out. Make sure your firewalls – your AWS security groups and anything installed on your server – allow port 443.
