Https not working after successful installation
Hello. I had working certificate, and since the renewal wasn’t working, i tried to reinstall it. After some attempts, this is the current situation. Thanks
My domain is: movieaddicted.net
I ran this command: certbot --apache
1: movieaddicted.net
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/movieaddicted.net.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/apache2/sites-available/movieaddicted.net-le-ssl.conf
Please choose whether HTTPS access is required or optional.
1: Easy - Allow both HTTP and HTTPS access to these sites
2: Secure - Make all requests redirect to secure HTTPS access
Redirecting vhost in /etc/apache2/sites-available/movieaddicted.net.conf to ssl vhost in /etc/apache2/sites-available/movieaddicted.net-le-ssl.conf
Congratulations! You have successfully enabled https://movieaddicted.net
https://www.ssllabs.com/ssltest/analyze.html?d=movieaddicted.net
My operating system is: Debian 8 (Jessie)
My web server is: Apache 2.4
My hosting provider, if applicable, is: Scaleway (VPS)
I can login to a root shell on my machine: Yes
I’m using a control panel to manage my site: No
I solved this issue, the topic can be closed, Thanks.
