Help installing in debian 8, avast ssl cert is loading
My domain is: dev.ottawakaraoke.com
I ran this command: sudo /usr/local/bin/certbot-auto
1: dev.ottawakaraoke.com
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/dev.ottawakaraoke.com.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/wordpress-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Future versions of Certbot will automatically configure the webserver so that all requests redirect to secure HTTPS access. You can control this behavior and disable this warning with the --redirect and --no-redirect flags.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://dev.ottawakaraoke.com
https://www.ssllabs.com/ssltest/analyze.html?d=dev.ottawakaraoke.com
   /etc/letsencrypt/live/dev.ottawakaraoke.com/fullchain.pem
   /etc/letsencrypt/live/dev.ottawakaraoke.com/privkey.pem
   Your cert will expire on 2020-04-21. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot-auto
   again with the "certonly" option. To non-interactively renew *all*
   of your certificates, run "certbot-auto renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
root@vps277963:/etc/apache2/sites-available# sudo /usr/local/bin/certbot-auto^C
root@vps277963:/etc/apache2/sites-available# clear
Congratulations! You have successfully enabled https://dev.ottawakaraoke.com
Server version: Apache/2.4.10 (Debian)
Server built:   Jan 29 2019 18:30:53
debian 8
ovh
yes, root
glorious all-mighty putty
CERTBOT 1.1.0
the SSL cert is showing:
Avast is an anti-virus/anti-malware program that seems to be protecting your http/https connections.
That is probably the case for any site you go to - you will see that same (local) cert.
If you want to see the real cert, you may need to temporarily disable Avast.
That is incorrect, what is showing is an LE cert:
https://www.ssllabs.com/ssltest/analyze.html?d=dev.ottawakaraoke.com&hideResults=on&latest
thanks.
it seems the hero image was not set to https.
@ianarman1… If there is an interest in terminating the MITM tls inspection take a look at this AVAST support information.
Hope this Helps
Rip
