hi guys, i installed certificate on my website, all working fine except on my iphone the page not load with HTTPS, only with HTTP, my site is:
http://aramaquinas.com.br (working on iphone but without css)
https://aramaquinas.com.br (not work on ios)
i test output ssl lab:
https://www.ssllabs.com/ssltest/analyze.html?d=aramaquinas.com.br
thank y’all
ios 11.0.2
schoen
October 4, 2017, 4:38am
#2
Olá @hdelima ,
Your certificate is from the cPanel certificate authority, not from Let’s Encrypt. Have you ever had a Let’s Encrypt certificate? There is none visible at
https://crt.sh/?Identity=%.aramaquinas.com.br
which means that have never had one from Let’s Encrypt, unless you obtained it within the last hour or so.
rg305
October 4, 2017, 4:52am
#3
It seems the site scripts are unaware of iOS version 11.0.2 and supply it a back-1 so that it shows the previous page.
like:
window.history.back();
javascript:history.go(-1)
hdelima
October 4, 2017, 10:53am
#4
thank you for reply, do they have anything to do with the ssl certificate?
hdelima
October 4, 2017, 10:55am
#5
wired, I think so I’ll check thank you for reply
rg305
October 4, 2017, 11:47am
#6
no, the certificate is good.
its possible the redirect occur only over HTTPS? cause HTTP the page open normal, I have no idea what happen =/
as you are not using a Let’s Encrypt certificate it’s unfair to post for help on this forum.
Most people here are volunteers and as such answering questions about generic web problems is not fair play.
I would suggest you contact cPanel about this issue as:
A) You are using their certificate and plugin
B) it’s most likely a cPanel related issue
Andrei
system
closed
November 5, 2017, 7:38am
#9
