Certificate not trusted
HTTPS works fine except on iPhone. Safari won't open the site and complains that it doesn't support TLS 1.2, but I've checked that it does indeed support TLS 1.2.
I went to SSL Checker to try to figure out the problem, and everything seems ok, except it also says: "Server certificate is not trusted by reputable certificate stores!"
The Certificate paths section has three steps, first two are ok, third one has an error:
"Extra download Not in trust store".
ISRG Root X1 (self-signed)
cabd2a79a1076a31f21d253635cb039d4329a5e8
RSA 4096 bits / SHA256withRSA
http://ssl-checker.online-domain-tools.com/
Not sure about what to do. Thankful for any help.
Regards,
Bjorn
My domain is: athletium.app
My web server is (include version): IIS 10
The operating system my web server runs on is (include version): Windows Server 2019
My hosting provider, if applicable, is: Hostwinds, VPS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): WinACME v2.1.16.1
Which version of iOS is the iPhone running?
Your certificate chain is fine, it's just using the modern Let's Encrypt chain instead of the "android compatible" one, this is normal on Windows servers.
The ssl checker you linked to is clearly not very good, use something else like SSL Server Test (Powered by Qualys SSL Labs)
Regarding TLS and Cipher suite compatibility, it looks OK but perhaps there is a problem with an older version of iOS. You can adjust your supported TLS and cipher suites without messing with the registry using the free tool Nartac Software - IIS Crypto then click 'Best Practise', apply that then restart the server.
Thanks webprofusion!
It's an iPhone 7 from last year, with iOS 14.2.
I cleared the browser cache again, and suddenly it works. Maybe Safari caches the certificate, or something similar. I'm confused, but now it works at least.
