Hello,
https://gethttpsforfree.com/ site is not working.
Earlier i used to generate ssl through this link. now it is not working. Please tell the reason
Hello,
The site gethttpsforfree.com isn't operated by Let's Encrypt. It's a third party web-based client for the Let's Encrypt server, operated by someone else.
Therefore, asking for the reason here is not likely going to give you an answer.
You should complain on the site itself, but that's obviously impossible, as the whole site is down ![]()
@rajamca66, as @Osiris said, that site is not related to Let’s Encrypt but you don’t need that site, you can download it to your own computer from here https://github.com/diafygi/gethttpsforfree click on green button (Clone or Download), download the zip file, extract it and execute index.html and you will have the same site but now in your own computer.
If you also want an alternative you can check this site https://zerossl.com/
Cheers,
sahsanu
