The problem:
Since 15th Oct 2020, we cannot create new certificate due letsencrypt bot cannot connect to our ip.
We have disabled our firewall, but it seems AWS (the provider of letsencrypt bot) is the one who block our ip.
While doing http-challenge the first bot coming from 64.78.149.164 and 66.133.109.36 has no problem accessing our ip
But the other bot coming from 3.22.70.135, 52.28.236.88, 18.196.96.172 cannot access our ip. We cannot even ping them (most likely due aws firewall)
Is there any possibility for letsencrypt using more provider? There must be someone else that also has this problem (AWS block some ip without reason)
bdmalay.com
certbot-auto certonly --manual
nginx
debian
no
certbot 0.28.00
