Continuing the discussion from Updating my e-mail address with certbot:
How can I renew this way with AWS Beanstalk file commands?
I have a file with all commands to build a website in AWS EBS.
The file that call to certbot command as below.
This is a good sh file. I still working with it until works fine.
/etc/letsencrypt/configs/generate-cert.sh:
mode: "000664"
owner: root
group: root
content: |
#!/bin/sh
_EMAIL=
_DOMAIN=
while getopts ":e:d:" OPTION;
do
case "${OPTION}" in
"e") _EMAIL="${OPTARG}";;
"d") _DOMAIN="${OPTARG}";;
esac
done
if [ -z "${_EMAIL}" ]; then
echo "Param email isn't specified!"
fi
if [ -z "${_DOMAIN}" ]; then
echo "Param domain isn't specified!"
fi
if [ -n "$_EMAIL" ] && [ -n "$_DOMAIN" ]; then
cd /opt/certbot/
./certbot-auto certonly \
--debug --non-interactive --email ${_EMAIL} \
--webroot -w /usr/share/nginx/html --agree-tos -d ${_DOMAIN} --keep-until-expiring
fi
if [ $? -ne 0 ]
then
ERRORLOG="/var/log/letsencrypt/letsencrypt.log"
echo "The Let's Encrypt cert has not been renewed!\n" >> $ERRORLOG
else
/etc/init.d/nginx reload
fi
exit 0
- – I think that this sh file needs to more information about the website and me.
The container commands as below:
container_commands:
00_removeconfig:
command: "rm -f /tmp/deployment/config/#etc#nginx#conf.d#00_elastic_beanstalk_proxy.conf /etc/nginx/conf.d/00_elastic_beanstalk_proxy.conf"
01_copy_conf_file:
command: "cp /etc/letsencrypt/configs/http_proxy.pre /etc/nginx/conf.d/http_proxy.conf; /etc/init.d/nginx reload"
02_createdir:
command: "mkdir /opt/certbot || true"
03_installcertbot:
command: "wget https://dl.eff.org/certbot-auto -O /opt/certbot/certbot-auto"
04_permission:
command: "chmod a+x /opt/certbot/certbot-auto"
05_getcert:
command: "sudo sh /etc/letsencrypt/configs/generate-cert.sh -e ${CERT_EMAIL} -d ${CERT_DOMAIN}"
06_link:
command: "ln -sf /etc/letsencrypt/live/${CERT_DOMAIN} /etc/letsencrypt/live/ebcert"
07_copy_ssl_conf_file:
command: "cp /etc/letsencrypt/configs/https_custom.pos /etc/nginx/conf.d/https_custom.conf; /etc/init.d/nginx reload"
08_cronjob_renew:
The command 08_cronjob_renew is lot there, but it can run to renew in somewhere.
Please I need a help.
