Well, currently there’s no way for you to get a certificate through non-DNS challenge types, because there is no IP address associated with almurjanholding.com nor www.almurjanholding.com. This would be required for the http-01 challenge. It is also required if you want people to surf to your website in the first place, so there’s something really wrong here!
Also, if you use CloudFlare, it’s not 100 % necessary to have a publically trusted certificate on your own server (the “origin” server in CloudFlare terms). See https://www.cloudflare.com/ssl/ for more information, especially the “Origin CA” part.
Hello everybody.
I have the same question/issue (How to renew certificate after expiry)
OS: Ubuntu 18.10
HTTP: Apache/2.4.34 (Ubuntu)
Domain: 8881000.com
I was late to renew my certificate by 8 hours.
sudo certbot --apache
certbot showed:
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/cnc.8881000.com/fullchain.pem
/etc/letsencrypt/live/cnc.8881000.com/privkey.pem
Your cert will expire on 2020-05-30. To obtain a new or tweaked . . .
You have a new certificate but your Apache server isn’t using it. Perhaps you should run sudo service apache2 reload, and also make sure that you didn’t copy the original certificate elsewhere and then configure Apache to use the copy rather than the original location (since the Certbot renewal will place the new certificate at the same path where the old certificate was located).
In the output from sudo certbot certificates, you can see that you have two different certificates:
One certificate in /etc/letsencrypt/live/8881000.com, which is expired (you apparently haven’t asked to renew it, or the renewal failed for another reason).
One certificate in /etc/letsencrypt/live/cnc.8881000.com, which was successfully renewed and is valid.
These certificates cover different sets of names.
But when we try to connect to https://cnc.8881000.com/, we see that the server shows us the other (expired) certificate, even though that certificate doesn’t cover the cnc subdomain at all. Could you look in your Apache configuration and see why Apache thinks it should use that certificate for the cnc subdomain? It seems like your HTTPS configuration might be the same across all of your subdomains—always pointing at the same certificate—even though you have two different certificates managed by Certbot, which therefore need different Apache configuration settings to reference each one.
