I ran this command: I am trying to install a cert using cloudpanel. I have another 7 domains and they all worked meaning I could install a cert but not with econship.
It produced this output:econoship.net: Domain could not be validated, error message: error type: urn:ietf:params:acme:error:dns, error detail: no valid A records found for econoship.net; no valid AAAA records found for econoship.net
My web server is (include version): nginx version: nginx/1.21.4
The operating system my web server runs on is (include version): Ubuntu 22.04.5 LTS
My hosting provider, if applicable, is: vultr
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): cloudpanel
Looks like you figured it out as both your registered name (econoship.net) and its www subdomain both have an IP address now.
You probably were not using the correct format for the IP address in your DNS control panel. My guess is that your second entry created a DNS record of econoship.net.econoship.net instead. Possibly because of the missing period after the name. I also guess you got instructions from your DNS provider.
In any case, I see you just got a cert for both names so you must have sorted it out.
