How to find out why a certificate was revoked without notice
My domain is: ds.home.zorbla.de
It appears, that the certificate that was issued in august was revoked on Oct 20 without prior notice. How can I find out why and by whom the certificate was revoked?
Hi @Dirk
there is a DiskStation, so it's a Synology.
There was a bug in DiskStation, certificates were revoked.
Check
and update your Synology.
Thanks for the hint.
Unfortunately, the faulty DSM version is still the latest version available. According to the linked article, the revocation of the cert happened shortly after renewing. I did not do anything on October 20. When the cert was revoked, I was well asleep. On october 22, I successfully renewed my cert and it’s stil good.
However, as I couldn’t connect to the GUI, I had to ssh to the DiskStation and issue
/usr/syno/sbin/syno-letsencrypt renew-all -vv
manually. No need to replace anything in the GUI.
(Just in case this helps anybody with the same issue).
I want to add that now pointed to the Synology, I searched the logs and found a bunch of log messages about syno-letsencrypt. To me it looks like the synology wanted to automatically renew the certificate (running a command “builtin-dyn-syno-letsencrypt-syno-letsencrypt - renew”).
