How to disable warning: "Your system is not supported by certbot-auto anymore."
sorry, I can't bring myself to post a customers domain here and let the world know how outdated their server is (read further an you'll probably understand).
./certbot/certbot-auto renew --quiet
stdout:
certbot-auto and its Certbot installation will no longer receive updates.
You will not receive any bug fixes including those fixing server compatibility
or security problems.
Please visit https://certbot.eff.org/ to check for other alternatives.
stderr:
/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/cryptography/hazmat/primitives/constant_time.py:26: CryptographyDeprecationWarning: Support for your Python version is deprecated. The next version of cryptography will remove support. Please upgrade to a release (2.7.7+) that supports hmac.compare_digest as soon as possible.
utils.PersistentlyDeprecated2018,
Apache/2.4.7 (Ubuntu)
Ubuntu 14.04.6 LTS
I'm sure that's irrelevant here
no
certbot 1.9.0
is there a way to disable the warning "Your system is not supported by certbot-auto anymore."?
Please let's not have a discussion about security and the importance of updates in this thread. I am well aware of that and I have already discussed the issue with the customer. In it's current desolate state, the particular system is not updatable anymore (from economic point of view). Snap is installed but not working. The only good thing is that the server isn't very exposed and it at least managed to stay under attacker's radar until now as it seems.
Kind regards
You could downgrade the discontinued certbot-auto script to a version where your system wasn't deprecated any longer and run it with the --no-self-upgrade option.
A different (and probably better) option would be to install certbot through pip using the pip instructions on the certbot site: https://certbot.eff.org/lets-encrypt/pip-apache
Note that certbot too doesn't support Python 2.7 any longer as far as I know. But I hope Ubuntu 14.04.6 LTS has Python 3+ support?
Thank you very much for your reply.
Python = 2.7.6
I fear pip install won't be possible. I am too scared to make too many changes to that system.
Hi @bugblatterbeast
Certbot may be the wrong tool.
Check other clients.
Perhaps acme.sh.
It should also have Python 3.4: http://releases.ubuntu.com/14.04/ubuntu-14.04.6-server-amd64.manifest
However, support for Python 3.4 has also been dropped from certbot :stuck_out_tongue:
Although some dependencies might be required to be installed globally, certbot itself would be installed in a Python virtual environment.
Thank you both very much.
The customer already agreed to have a new server set up. However it will take a while until all the customised services will be transferred. He asked me if it would be possible to switch off those certbot warnings until then.
I will take some time to look into the acme.sh solution and decide between that and the downgrade. I don't want to spend too much effort on this sinking ship.
I'll let you know how it worked out.
Thanks again and have a nice holiday. Kind regards
Another "solution" is to ignore the warning, as it's just that: a warning. Especially as a new server is already being set up.
One option not mentioned is that you may invoke the underlying installation of Certbot directly via /opt/eff.org/certbot/venv/bin/certbot.
Hm, that's even a better option! I was just typing a post about removing the warning from certbot-auto script, but indeed, the script doesn't do anything any longer anyway.. So it's a great idea to just bypass it altogether :slight_smile:
Thanks all!
This:
/opt/eff.org/certbot/venv/bin/certbot renew --quiet
got rid of the stdout message but the stderr is still showing.
If I'd run
/opt/eff.org/certbot/venv/bin/letsencrypt renew --quiet 2> /dev/null
would that lead to losing information about problems with cert renewal?
It seem so:
server renewal # certbot renew --cert-name le-test-01.example.com --dry-run -q
Challenge failed for domain le-test-01.example.com
Failed to renew certificate le-test-01.example.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
  /etc/letsencrypt/live/le-test-01.example.com/fullchain.pem (failure)
server renewal # certbot renew --cert-name le-test-01.example.com --dry-run -q 2>/dev/null
server renewal #
However, you could pipe stderr to stdout and grep the deprecation warning line(s) away like so:
server renewal # certbot renew --cert-name le-test-01.example.com --dry-run -q 2>&1 | grep -v CryptographyDeprecationWarning
server renewal #
If there are a multiple of lines, you could grep those out with specific grep -v targets too of course :slight_smile:
Very smart idea to use the inversive grep.
It were two lines and this did it:
/opt/eff.org/certbot/venv/bin/letsencrypt renew --quiet 2>&1 | grep -v "CryptographyDeprecationWarning\|utils.PersistentlyDeprecated"
Thanks everyone!
