How to diagnostic "Too many flags setting configurators/installers/authenticators 'webroot' -> 'apache'"
Hi, I'm upgrading from letsencrypt-auto to certbot-auto by following the instructions in Certbot . However, I encountered an issue as described below:
new.forest.go.th
# ./certbot-auto --apache
My operating system is:
Ubuntu 14.04.4 LTS, Trusty Tahr
My web server is:
Apache/2.4.7 (Ubuntu)
I can login to a root shell on my machine:
letsencrypt.log:
2016-07-21 03:39:32,152:DEBUG:certbot.main:Root logging level set at 30
2016-07-21 03:39:32,152:INFO:certbot.main:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2016-07-21 03:39:32,152:DEBUG:certbot.main:certbot version: 0.8.1
2016-07-21 03:39:32,152:DEBUG:certbot.main:Arguments: ['--apache', '-c', 'cli.ini']
2016-07-21 03:39:32,152:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#webroot,PluginEntryPoint#null,PluginEntryPoint#manual,PluginEntryPoint#standalone)
How can I get more info to fix the problem?
Thank you.
There’s probably a conflicting setting in your cli.ini
But I didn’t create any cli.ini for certbot-auto – just wgeted it from internet.
I even created another cli.ini (copied the content from https://github.com/certbot/certbot/blob/master/examples/cli.ini ) alongside certbot-auto and run:
# ./certbot-auto --apache -c cli.ini
But the result was still the same.
the problem for me was the old letsencrypt install
doing a “sudo apt-get purge letsencrypt” ensuring the /etc/letsencrypt folder is emptied out fixed that particular error
I then had to work through about a million more errors with ssl configs.
