Too many flags setting configurators/installers/authenticators 'webroot' -> 'apache'
Too many flags setting configurators/installers/authenticators ‘webroot’ -> ‘apache’
cat /var/log/letsencrypt/letsencrypt.log
2020-05-04 16:57:35,680:DEBUG:certbot._internal.main:certbot version: 1.0.0
2020-05-04 16:57:35,681:DEBUG:certbot._internal.main:Arguments: [’–apache’]
2020-05-04 16:57:35,681:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-05-04 16:57:35,703:DEBUG:certbot._internal.log:Root logging level set at 20
2020-05-04 16:57:35,704:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Server version: Apache/2.4.33 (Linux/SUSE)
Server built: 2019-08-28 06:00:22.000000000 +0000
NAME=“openSUSE Leap”
VERSION=“15.1”
ID=“opensuse-leap”
ID_LIKE=“suse opensuse”
VERSION_ID=“15.1”
PRETTY_NAME=“openSUSE Leap 15.1”
ANSI_COLOR=“0;32”
CPE_NAME=“cpe:/o:opensuse:leap:15.1”
BUG_REPORT_URL=“https://bugs.opensuse.org
HOME_URL=“https://www.opensuse.org/
My hosting provider, if applicable, is: No hosted, I have full access.
I can login to a root shell on my machine: YES
I’m using a control panel to manage my site :NO
The version of my client is: certbot 1.0.0
Looks like this is similar to a very old thread...
Before you do anything, backup your Let's Encrypt folder. (Normally in /etc/letsencrypt)
If you can, try to see if you have a cli.ini set in your system.
There's an extreme version:
Thanks. Also I dont have yet a FQDN, is mandatory? because my server has public IP address, and I read you can have ssl cert without FQDN.
rsa-key-size = 4096
server = https://acme-staging.api.letsencrypt.org/directory
agree-tos = True
renew-by-default = True
authenticator = webroot
webroot-path = /srv/www/htdocs
I dont have old installs, this is my first time in this server
Hi @viciexperts
if you want to create a Letsencrypt certificate, a domain name is required.
There are certificates (see https://1.1.1.1/ ), but Letsencrypt doesn't allow to create certificates with ip addresses.
Check that .ini line and remove the authenticator line.
certbot --apache
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): myemail@server.com
An unexpected error occurred:
The client lacks sufficient authorization :: Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details.
2020-05-05 10:07:27,025:DEBUG:certbot._internal.main:certbot version: 1.0.0
2020-05-05 10:07:27,026:DEBUG:certbot._internal.main:Arguments: [’–apache’]
2020-05-05 10:07:27,026:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-05-05 10:07:27,049:DEBUG:certbot._internal.log:Root logging level set at 20
2020-05-05 10:07:27,050:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-05-05 10:07:27,050:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2020-05-05 10:07:27,213:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.33
2020-05-05 10:07:28,220:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache._internal.entrypoint:ENTRYPOINT
Initialized: <certbot_apache._internal.override_suse.OpenSUSEConfigurator object at 0x7f6ccc8e6990>
Prep: True
2020-05-05 10:07:28,221:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_apache._internal.override_suse.OpenSUSEConfigurator object at 0x7f6ccc8e6990> and installer <certbot_apache._internal.override_suse.OpenSUSEConfigurator object at 0x7f6ccc8e6990>
2020-05-05 10:07:28,221:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2020-05-05 10:07:40,923:DEBUG:acme.client:Sending GET request to https://acme-staging.api.letsencrypt.org/directory.
2020-05-05 10:07:40,925:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org:443
2020-05-05 10:07:41,138:DEBUG:urllib3.connectionpool:https://acme-staging.api.letsencrypt.org:443 “GET /directory HTTP/1.1” 200 704
2020-05-05 10:07:41,139:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Tue, 05 May 2020 14:07:41 GMT
Content-Length: 704
Replay-Nonce: 0001896nGwKuOhnfzlGTXYm90fm1UfkaI7_QF6YYylXUVE0
X-Frame-Options: DENY
“key-change”: “https://acme-staging.api.letsencrypt.org/acme/key-change”,
“meta”: {
“caaIdentities”: [
letsencrypt.org
“terms-of-service”: “https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf”,
“website”: “https://letsencrypt.org/docs/staging-environment/
“new-authz”: “https://acme-staging.api.letsencrypt.org/acme/new-authz”,
“new-cert”: “https://acme-staging.api.letsencrypt.org/acme/new-cert”,
“new-reg”: “https://acme-staging.api.letsencrypt.org/acme/new-reg”,
“revoke-cert”: “https://acme-staging.api.letsencrypt.org/acme/revoke-cert”,
“w2NlDN3OW_M”: “Adding random entries to the directory
2020-05-05 10:07:41,140:DEBUG:acme.client:Requesting fresh nonce
2020-05-05 10:07:41,140:DEBUG:acme.client:Sending HEAD request to https://acme-staging.api.letsencrypt.org/acme/new-reg.
2020-05-05 10:07:41,187:DEBUG:urllib3.connectionpool:https://acme-staging.api.letsencrypt.org:443 “HEAD /acme/new-reg HTTP/1.1” 405 0
2020-05-05 10:07:41,188:DEBUG:acme.client:Received response:
HTTP 405
Server: nginx
Content-Type: application/problem+json
Content-Length: 91
Allow: POST
Replay-Nonce: 0002NzJt34j6WIONSuZ1_rdXa5OzYtgS-0apRzS8Rc2F2mc
2020-05-05 10:07:41,188:DEBUG:acme.client:Storing nonce: 0002NzJt34j6WIONSuZ1_rdXa5OzYtgS-0apRzS8Rc2F2mc
2020-05-05 10:07:41,189:DEBUG:acme.client:JWS payload:
“contact”: [
mailto:email@servers.com
“resource”: “new-reg”
2020-05-05 10:07:41,227:DEBUG:acme.client:Sending POST request to https://acme-staging.api.letsencrypt.org/acme/new-reg:
“protected”: “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”,
“payload”: “ewogICJjb250YWN0IjogWwogICAgIm1haWx0bzpvbWFyQHZpY2lleHBlcnRzLmNvbSIKICBdLCAKICAicmVzb3VyY2UiOiAibmV3LXJlZyIKfQ”,
“signature”: “nGY5usfmH_sdXeQhAPEO2y_hJUYfkttPPVQCi-8Ia3snpfI4lDtA_ZysqS579Kyyy1p07DJ3EmvUoUB7zpw8kokj93B_unA34rAiJ8zvYsFoOWfaFZCPj4DgHkAWgnx45GvweF22Ciw84gmAc6yWImLqcwWck1ouI6zsFzUiBZZq3loUBXAlc54x7WCbLDOBTQwTXlmZFZ40HzMmVrWdi4ASZ3-5Vzt-S3iYss33Ms0IfvXDmyohbUMq3hDgZps20p5fsYpBo-Xd6H31kgCvVujY-9RHBDv1Md6lQeywHe0KCXOCrbIm9EIEVAEINC8khSVLugoKoHyjOkqFApUxq1nlewvqEtdzivTNcJMTtvAsEs8VbIgNrUGxzbHXR7-zwZGgITrGeV4zJNWef53TceSx_Df-c0_J3y8NGvmXgAFfU21LW96mKS_WzQ”
2020-05-05 10:07:41,293:DEBUG:urllib3.connectionpool:https://acme-staging.api.letsencrypt.org:443 “POST /acme/new-reg HTTP/1.1” 403 280
2020-05-05 10:07:41,294:DEBUG:acme.client:Received response:
HTTP 403
Server: nginx
Content-Length: 280
Replay-Nonce: 0001Jn8zfPOFnKSYu9hKi3xbZPpyo7irl_DJfktlkQ19Kck
“type”: “urn:acme:error:unauthorized”,
“detail”: “Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details.”,
“status”: 403
2020-05-05 10:07:41,295:DEBUG:certbot._internal.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==1.0.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 14, in main
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1350, in main
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1097, in run
le_client = _init_le_client(config, authenticator, installer)
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 607, in _init_le_client
acc, acme = _determine_account(config)
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 523, in _determine_account
config, account_storage, tos_cb=_tos_cb)
File “/usr/lib/python2.7/site-packages/certbot/_internal/client.py”, line 177, in register
regr = perform_registration(acme, config, tos_cb)
File “/usr/lib/python2.7/site-packages/certbot/_internal/client.py”, line 220, in perform_registration
return acme.new_account_and_tos(newreg, tos_cb)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 848, in new_account_and_tos
regr = self.client.register(regr)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 277, in register
response = self._post(self.directory[new_reg], new_reg)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 95, in _post
return self.net.post(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 1191, in post
return self._post_once(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 1205, in _post_once
response = self._check_response(response, content_type=content_type)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 1061, in _check_response
raise messages.Error.from_json(jobj)
Error: urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details.
2020-05-05 10:07:41,298:ERROR:certbot._internal.log:An unexpected error occurred:
2020-05-05 10:07:41,298:ERROR:certbot._internal.log:The client lacks sufficient authorization :: Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details.
ACME-v1 is deprecated.
Use acme-v02.api.letsencrypt.org instead.
Read
There are more lines in that cli.ini which should be removed.
renew-by-default = True is a recipe to running into rate limts… Should be removed. Also, the server line doesn’t need to be modified, with version 1.0.0 the ACME v2 endpoint is enabled by default, so the server line can be removed in total too. Use the --staging command line option for using the staging environment. Remove the --staging option if all testing is succesful and you want a live certificate.
Thank you, I think that now works because it shows:
1: dynportal.company.com
2: vicibox.company.com
3: dynportalcompany.com
I had to edit apache2/vhosts.d/1111-default-ssl.conf and add my FQDN
also, I had to disable the firewall.
and said:
    /etc/letsencrypt/live/dialer2.callcentre.org/fullchain.pem
    /etc/letsencrypt/live/dialer2.callcentre.org/privkey.pem
    Your cert will expire on 2020-08-03. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    “certbot renew”
But when I access my server using https still said not valid certicate.
Your connection is not private
NET::ERR_CERT_AUTHORITY_INVALID
I also edited apache2/vhosts.d/1111-default-ssl.conf and changed these lines:
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/dialer2.callcentre.org/fullchain.pem
#SSLCACertificateFile /etc/apache2/ssl.crt/CA_chain.crt
SSLCertificateKeyFile /etc/letsencrypt/live/dialer2.callcentre.org/privkey.pem
And finally WORKS!
Thank you very much!
