Issue running Certbot on openSuSE 15.1
sudo certbot --apache
2020-08-17 12:48:11,257:DEBUG:certbot._internal.main:certbot version: 1.0.0
2020-08-17 12:48:11,260:DEBUG:certbot._internal.main:Arguments: [’–apache’]
2020-08-17 12:48:11,262:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-08-17 12:48:11,295:DEBUG:certbot._internal.log:Root logging level set at 20
2020-08-17 12:48:11,298:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-08-17 12:48:11,299:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2020-08-17 12:48:11,438:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.33
2020-08-17 12:48:12,548:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache._internal.entrypoint:ENTRYPOINT
Initialized: <certbot_apache._internal.override_suse.OpenSUSEConfigurator object at 0x7f31e714e6d8>
Prep: True
2020-08-17 12:48:12,551:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_apache._internal.override_suse.OpenSUSEConfigurator object at 0x7f31e714e6d8> and installer <certbot_apache._internal.override_suse.OpenSUSEConfigurator object at 0x7f31e714e6d8>
2020-08-17 12:48:12,551:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2020-08-17 12:48:22,490:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2020-08-17 12:48:22,496:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2020-08-17 12:48:22,529:DEBUG:certbot._internal.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==1.0.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3.6/site-packages/certbot/main.py”, line 14, in main
File “/usr/lib/python3.6/site-packages/certbot/_internal/main.py”, line 1350, in main
File “/usr/lib/python3.6/site-packages/certbot/_internal/main.py”, line 1097, in run
le_client = _init_le_client(config, authenticator, installer)
File “/usr/lib/python3.6/site-packages/certbot/_internal/main.py”, line 607, in _init_le_client
acc, acme = _determine_account(config)
File “/usr/lib/python3.6/site-packages/certbot/_internal/main.py”, line 523, in _determine_account
config, account_storage, tos_cb=_tos_cb)
File “/usr/lib/python3.6/site-packages/certbot/_internal/client.py”, line 175, in register
acme = acme_from_config_key(config, key)
File “/usr/lib/python3.6/site-packages/certbot/_internal/client.py”, line 45, in acme_from_config_key
return acme_client.BackwardsCompatibleClientV2(net, key, config.server)
File “/usr/lib/python3.6/site-packages/acme/client.py”, line 827, in init
directory = messages.Directory.from_json(net.get(server).json())
File “/usr/lib/python3.6/site-packages/acme/client.py”, line 1158, in get
self._send_request(‘GET’, url, **kwargs), content_type=content_type)
File “/usr/lib/python3.6/site-packages/acme/client.py”, line 1107, in _send_request
response = self.session.request(method, url, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 343, in _make_request
self._validate_conn(conn)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 839, in validate_conn
conn.connect()
File “/usr/lib/python3.6/site-packages/urllib3/connection.py”, line 344, in connect
ssl_context=context)
File "/usr/lib/python3.6/site-packages/urllib3/util/ssl
.py", line 319, in ssl_wrap_socket
context.load_verify_locations(ca_certs, ca_cert_dir)
File “/usr/lib/python3.6/site-packages/urllib3/contrib/pyopenssl.py”, line 428, in load_verify_locations
self._ctx.load_verify_locations(cafile, capath)
File “/usr/lib/python3.6/site-packages/OpenSSL/SSL.py”, line 775, in load_verify_locations
_raise_current_error()
File “/usr/lib/python3.6/site-packages/OpenSSL/_util.py”, line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error:
2020-08-17 12:48:22,544:ERROR:certbot._internal.log:An unexpected error occurred:
apache2 -2.4.33
openSuSE 15.1
Yes
NO
certbot 1.0.0
Thanks
Is that really how the error appears in /var/log/letsencrypt/letsencrypt.log?
Seems that the error has something to do with OpenSSL loading your trusted CA certificates off the filesystem, but the cause of the error is obscured.
Certbot seems to work fine on a fresh 15.1 system, so I think we need help from your logs.
Also, does this work on your system?
curl -I https://acme-v02.api.letsencrypt.org/directory
Thanks for the reply.
That is how the error appears.. I've copied it straight out.
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
I hope that helps..
