Where can I see more information about what’s wrong? Neither logs/www.mydomain.com-error_log nor logs/www.mydomain.com-access_log even show anything about my attempt to connect through https.
Thank you.
Changing to *:443 and restart still gives same result. “apachectl -t” says Syntax OK but I think it is not looking at my actual apache config because I am using LAMPP and I don’t know the equivalent command. I restart apache with the following command.
Is there any kind of log file that will show me what is happening when I try to access the site through https? Now I only see mydomain.com refused to connect in browser. That doesn’t tell me much.
Also I actually have a couple different VirtualHost blocks in the httpd-vhost.conf file with different domain names. If I use *:443 I can’t distinguish them anymore.
EDIT: BTW, the site is wordpress, does that make any difference?
