How to create a SAN certificate in nginx for sub-domains?
My domain is: domain.com
My web server is (include version): ngnix 1.18
The operating system my web server runs on is (include version): ubuntu 20.04.1
My hosting provider, if applicable, is: digital ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
i do not know the commands to make a SAN cert for 4 subdomains
login.domain.com
api.domain.com
listener.domain.com
my sequence to make SSL are
  1. cd /etc/nginx/sites-available
  2. in sites-available
    i create a file www.domain.com
    the file looks like this
listen 80;
listen [::]:80;
server_name domain.com;
return 301 http://www.domain.com$request_uri;
listen 80;
listen [::]:80;
server_name www.domain.com;
root /var/www/www.domain.com/;
client_max_body_size 100m;
access_log /var/log/nginx/www.domain.com-access.log;
error_log /var/log/nginx/www.domain.com-error.log;
index index.php index.html;
location ~ \.php$ {
    try_files $uri $uri/ /index.php?$args;
    fastcgi_pass unix:/var/run/php/php7.2-fpm.sock;
    fastcgi_index index.php;
    fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
    include fastcgi_params;
  1. cd /etc/nginx/sites-enabled/
    i link things
    ln -sf /etc/nginx/sites-available/www.domain.com www.domain.com
  2. certbot --nginx
You could add each of those domains in the relevant server_name in your configuration and Certbot would pick them up when you ran certbot --nginx.
You could alternatively ask Certbot to create a certificate with a certain list of domains:
certbot --nginx -d domain.com -d login.domain.com -d api.domain.com -d listener.domain.com
Thank you for your response.
Are your instructions above for a wildcard or SAN?
Will I need to do anything on the DNS side besides A Record with the subdomain name?
That's for a SAN certificate, yes.
For a wildcard you would do -d "*.example.com". Wildcards have some other complications: you have to use the DNS challenge. It's much easier and recommended to stick to SAN certificates if you can.
Nothing else. All you need is for the A record of each subdomain to point to your nginx server.
Thank you very much for your help.
After the certificates are made, what happens if in the future, I add a new subdomain
new.domain.com
What command would I run for the new subdomain?
One way is to first find your Certificate Name by running:
certbot certificates
Then run the command you originally used, but:
  • Include the new subdomain in the list of domains, and
  • Include the Certificate Name you found using --cert-name, so that Certbot knows you want to update the existing certificate
That might look something like:
certbot --nginx --cert-name domain.com \
-d domain.com -d login.domain.com -d api.domain.com -d listener.domain.com \
-d the-new-subdomain.domain.com
The only things that changed are --cert-name domain.com and -d the-new-subdomain.domain.com.
