CRON and SYSTEMD are different things.
They both do the same kinds of things but are not related to each other.
To see if CRON actually ran at 00:41, you would have to check your firewall logs (if you have any) or maybe the LE log file (but that may also be empty since we used the -q parameter)
I started getting errors when the other domains that we are not using needed to be renewed
-rw-r–r-- 1 root root 509 Sep 13 11:45 kentivo.de.conf
-rw-r–r-- 1 root root 529 Sep 13 11:34 www.kentivo.de.conf
The server was down and we got this
AH00060: seg fault or similar nasty error detected in the parent process
AH00098: pid file /var/run/apache2/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
AH00489: Apache/2.4.25 (Debian) mod_fcgid/2.3.9 OpenSSL/1.0.2s configured -- resuming normal operations
Command line: '/usr/sbin/apache2'
AH00491: caught SIGTERM, shutting down
AH00094: Command line: '/usr/sbin/apache2'
From the log /var/log/letsencrypt/letsencrypt.log
I can separate this as important or I can send you the whole log privately there is some sensitive info in there.
Domain: kentivo.de
Detail: Invalid response from http://kentivo.com/?lang=de [IP ADDRESS]: "<!DOCTYPE html>\n<html lang=\"de-DE\">\n<head>\n<meta charset=\"UTF-8\">\n<meta name=\"viewport\" content=\"width=device-width, initial-sca"
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
2019-11-14 12:46:11,399:DEBUG:certbot.error_handler:Encountered exception:
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 91, in handle_authorizations
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 180, in _poll_authorizations
AuthorizationError: Some challenges have failed.
I have removed the cron job until I fix this because it will just keep downing the server.
But the error causing it to go off rails is the two domains that are trying to update, can I delete those certificates safely ? They are not in use anyway.
Last time I tried deleting certificates my server went to hell and everything was causing an error code and couldn't restore my server.
I want to do it only if I can do it right and remove those two domains so that there are no more errors caused, As I have just added one new domain with the command sudo certbot-auto --apache -d example.com -d www.example.com
Now I have this
ls -l /etc/letsencrypt/renewal/
total 20
-rw-r--r-- 1 root root 544 Nov 15 15:30 alpha.kentivo.com.conf
-rw-r--r-- 1 root root 540 Nov 10 12:44 elami.mk.conf
-rw-r--r-- 1 root root 590 Nov 10 12:46 justsayingkiddo.nl.conf
-rw-r--r-- 1 root root 509 Sep 13 11:45 kentivo.de.conf
-rw-r--r-- 1 root root 529 Sep 13 11:34 www.kentivo.de.conf
