I would like to create automatic renwal for my domains, because i Have had some bad luck in the past without looking into it I have made some mistakes that cost me dearly.
I would like to know if there is a tutorial or something similar to recommend me so i don’t mess everything up. Thank you.
My domain is: www.elami.mk
Distributor ID: Debian
Description: Debian GNU/Linux 9.9 (stretch)
Release: 9.9
Codename: stretch
Apache/2.4.25 (Debian)
I can login to a root shell on my machine (yes or no, or I don’t know): YES
No, I use terminal
certbot 0.40.1 (cannot find where is located)
rg305
November 7, 2019, 11:02am
2
which certbot
find / -name certbot
Please show:
systemctl status certbot
systemctl list-timers certbot.timer
which certbot
/opt/letsencrypt/certbot
/opt/eff.org/certbot
/opt/eff.org/certbot/venv/bin/certbot
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot
Unit certbot.service could not be found.
0 timers listed.
Pass --all to see loaded but inactive timers, too.
rg305
November 7, 2019, 11:31am
4
Please show:
find / -name certbot*
#use your actual root username:
crontab -u root -l
EDIT: be sure to be logged as root user or use sudo for these commands
rg305:
/opt/letsencrypt/docs/man/certbot.rst
/opt/letsencrypt/certbot-ci
/opt/letsencrypt/certbot-ci/certbot_integration_tests
/opt/letsencrypt/certbot-ci/certbot_integration_tests/utils/certbot_call.py
/opt/letsencrypt/certbot-ci/certbot_integration_tests/certbot_tests
/opt/letsencrypt/certbot-dns-luadns
/opt/letsencrypt/certbot-dns-luadns/certbot_dns_luadns
/opt/letsencrypt/certbot-dns-cloudflare
/opt/letsencrypt/certbot-dns-cloudflare/certbot_dns_cloudflare
/opt/letsencrypt/certbot-apache
/opt/letsencrypt/certbot-apache/certbot_apache
/opt/letsencrypt/certbot-apache/certbot_apache/tests/testdata/debian_apache_2_4/ multiple_vhosts/apache2/sites-available/certbot.conf
/opt/letsencrypt/certbot-apache/certbot_apache/tests/testdata/debian_apache_2_4/ multiple_vhosts/apache2/sites-enabled/certbot.conf
/opt/letsencrypt/certbot-dns-route53
/opt/letsencrypt/certbot-dns-route53/certbot_dns_route53
/opt/letsencrypt/certbot-auto
/opt/letsencrypt/certbot-dns-google
/opt/letsencrypt/certbot-dns-google/certbot_dns_google
/opt/letsencrypt/certbot-nginx
/opt/letsencrypt/certbot-nginx/certbot_nginx
/opt/letsencrypt/certbot-dns-gehirn
/opt/letsencrypt/certbot-dns-gehirn/certbot_dns_gehirn
/opt/letsencrypt/certbot-dns-dnsmadeeasy
/opt/letsencrypt/certbot-dns-dnsmadeeasy/certbot_dns_dnsmadeeasy
/opt/letsencrypt/certbot-compatibility-test
/opt/letsencrypt/certbot-compatibility-test/certbot_compatibility_test
/opt/letsencrypt/certbot-dns-rfc2136
/opt/letsencrypt/certbot-dns-rfc2136/certbot_dns_rfc2136
/opt/letsencrypt/certbot-dns-ovh
/opt/letsencrypt/certbot-dns-ovh/certbot_dns_ovh
/opt/letsencrypt/certbot-dns-dnsimple
/opt/letsencrypt/certbot-dns-dnsimple/certbot_dns_dnsimple
/opt/letsencrypt/certbot-dns-digitalocean
/opt/letsencrypt/certbot-dns-digitalocean/certbot_dns_digitalocean
/opt/letsencrypt/letsencrypt-auto-source/certbot-auto.asc
/opt/letsencrypt/letsencrypt-auto-source/pieces/certbot-requirements.txt
/opt/letsencrypt/windows-installer/certbot.ico
/opt/letsencrypt/examples/plugins/certbot_example_plugins.py
/opt/letsencrypt/certbot-dns-sakuracloud
/opt/letsencrypt/certbot-dns-sakuracloud/certbot_dns_sakuracloud
/opt/letsencrypt/certbot-dns-linode
/opt/letsencrypt/certbot-dns-linode/certbot_dns_linode
/opt/letsencrypt/certbot-dns-cloudxns
/opt/letsencrypt/certbot-dns-cloudxns/certbot_dns_cloudxns
/opt/letsencrypt/certbot-dns-nsone
/opt/letsencrypt/certbot-dns-nsone/certbot_dns_nsone
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_nginx-0.40.1.dist- info
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache-0.40.1.dist -info
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot-0.40.1.dist-info
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testd ata/debian_apache_2_4/multiple_vhosts/apache2/sites-available/certbot.conf
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testd ata/debian_apache_2_4/multiple_vhosts/apache2/sites-enabled/certbot.conf
/opt/eff.org/certbot/venv/certbot-auto-bootstrap-version.txt
/usr/local/sbin/certbot-auto
rg305:
NEXT LEFT LAST PASSED UNIT ACTIVATES
Thu 2019-11-07 11:39:00 UTC 5min left Thu 2019-11-07 11:09:02 UTC 24min ago phpsessionclean.timer phpsessionclean.service
Thu 2019-11-07 14:47:11 UTC 3h 13min left Wed 2019-11-06 14:47:11 UTC 20h ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Thu 2019-11-07 17:18:39 UTC 5h 45min left Thu 2019-11-07 05:44:48 UTC 5h 48min ago apt-daily.timer apt-daily.service
Fri 2019-11-08 06:11:31 UTC 18h left Thu 2019-11-07 06:04:35 UTC 5h 28min ago apt-daily-upgrade.timer apt-daily-upgrade.service
4 timers listed.
sudo crontab -u root -l
no crontab for root
rg305
November 7, 2019, 11:38am
6
OK, so your running certbot-auto
But there was not timer automatically created for renewals...
[that should have been done for you]
rg305
November 7, 2019, 11:41am
7
OK, the simplest is to use cron
What command are you currently using to renew?
I still havent needed to renew, the websites are younger than 90 days and just wanted to prepare ahead of time and set up automatic renewal and not mess anything up along the way,
rg305
November 7, 2019, 11:45am
9
OK.
Here is a starting point for your cron renewal entry:
41 */12 * * * /usr/local/sbin/certbot-auto --apache -q --deploy-hook '/etc/init.d/apache2 restart'
Test that with:
/usr/local/sbin/certbot-auto --apache --deploy-hook '/etc/init.d/apache2 restart'
I just copy all of this into terminal and run ?
rg305
November 7, 2019, 11:48am
11
From cron job NO
That requires using an editor (via crontab -e)
[https://www.ostechnix.com/a-beginners-guide-to-cron-jobs/ ]
Start with the TEST command first - see if that "works".
Try from terminal prompt:
sudo /usr/local/sbin/certbot-auto --apache --deploy-hook '/etc/init.d/apache2 restart'
I copy this command exactly like this and run it as sudo su ?
sudo /usr/local/sbin/certbot-auto --apache --deploy-hook ’ /etc/init.d/apache2 restart’
1: elami.mk
2: www.elami.nl
3: www.elami.mk
blank to select all options shown (Enter ‘c’ to cancel): An unexpected error occ urred:
error: (4, ‘Interrupted system call’)
rg305
November 7, 2019, 12:02pm
15
So you don’t yet have a certificate?
Enter “c” and cancel that.
Show:
certbot-auto certificates
Found the following certs:
Certificate Name: elami.mk
Domains: elami.mk www.elami.mk
Expiry Date: 2019-12-10 10:18:04+00:00 (VALID: 32 days)
Certificate Path: /etc/letsencrypt/live/elami.mk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/elami.mk/privkey.pem
Certificate Name: justsayingkiddo.nl
Domains: justsayingkiddo.nl www.justsayingkiddo.nl
Expiry Date: 2019-12-10 10:52:58+00:00 (VALID: 32 days)
Certificate Path: /etc/letsencrypt/live/justsayingkiddo.nl/fullchain.pem
Private Key Path: /etc/letsencrypt/live/justsayingkiddo.nl/privkey.pem
Certificate Name: kentivo.de
Domains: kentivo.de
Expiry Date: 2019-12-12 10:45:26+00:00 (VALID: 34 days)
Certificate Path: /etc/letsencrypt/live/kentivo.de/fullchain.pem
Private Key Path: /etc/letsencrypt/live/kentivo.de/privkey.pem
Certificate Name: www.kentivo.de
Domains: www.kentivo.de kentivo.nl www.kentivo.nl
Expiry Date: 2019-12-12 10:34:56+00:00 (VALID: 34 days)
Certificate Path: /etc/letsencrypt/live/www.kentivo.de/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.kentivo.de/privkey.pem
EDIT: The other domains listed here were also listed up there but I deleted them because I thought they were not relevant, but they are apparently so they were on the list up there also.
rg305
November 7, 2019, 12:06pm
17
Interesting…
You have certs, but certbot-auto doesn’t know where/how they are being used…
Please show:
ls -l /etc/letsencrypt/renewal/
total 16
-rw-r--r-- 1 root root 499 Sep 11 11:18 elami.mk.conf
-rw-r--r-- 1 root root 549 Sep 11 11:53 justsayingkiddo.nl.conf
-rw-r--r-- 1 root root 509 Sep 13 11:45 kentivo.de.conf
-rw-r--r-- 1 root root 529 Sep 13 11:34 www.kentivo.de.conf
rg305
November 7, 2019, 12:09pm
19
Please show:
[don’t show account numbers]
cat /etc/letsencrypt/renewal/elami.mk.conf
renew_before_expiry = 30 days
version = 0.38.0
archive_dir = /etc/letsencrypt/archive/elami.mk
cert = /etc/letsencrypt/live/elami.mk/cert.pem
privkey = /etc/letsencrypt/live/elami.mk/privkey.pem
chain = /etc/letsencrypt/live/elami.mk/chain.pem
fullchain = /etc/letsencrypt/live/elami.mk/fullchain.pem
[renewalparams]
authenticator = apache
installer = apache
account =
