OK, let’s try just that one cert:
sudo /usr/local/sbin/certbot-auto renew --apache --cert-name elami.mk --deploy-hook '/etc/init.d/apache2 restart'
I think I found MY MISTAKE - was missing “renew” in command.
sudo /usr/local/sbin/certbot-auto --apache --cert-name elami.mk --deploy-hook '/etc/init.d/apache2 restart'
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/elami.mk.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
What do I click ?
press C
Let’s try it with “renew”:
sudo /usr/local/sbin/certbot-auto renew --apache --deploy-hook '/etc/init.d/apache2 restart'
Processing /etc/letsencrypt/renewal/elami.mk.conf
Processing /etc/letsencrypt/renewal/justsayingkiddo.nl.conf
Processing /etc/letsencrypt/renewal/kentivo.de.conf
Processing /etc/letsencrypt/renewal/www.kentivo.de.conf
/etc/letsencrypt/live/elami.mk/fullchain.pem expires on 2019-12-10 (skipped)
/etc/letsencrypt/live/justsayingkiddo.nl/fullchain.pem expires on 2019-12-10 (skipped)
/etc/letsencrypt/live/kentivo.de/fullchain.pem expires on 2019-12-12 (skipped)
/etc/letsencrypt/live/www.kentivo.de/fullchain.pem expires on 2019-12-12 (skipped)
No renewals were attempted.
No hooks were run.
Perfect !
Now we just need to add that command to CRON so that is runs automatically.
Amazing!
You are the best!
EDIT: I read about CRON (the link you provided) I get what it does.
One last check:
Let’s make sure the “restart” will work when called:
Try:
sudo /etc/init.d/apache2 restart
[ ok ] Restarting apache2 (via systemctl): apache2.service.
Perfect!
Cheers from Miami
Thank you very much, please provide a patreon link or something similar you use
Also wanted to ask, is there like a default cron command I can copy paste into cron so it does the trick ?
The tutorials online say start moving certbot here and there… simply doesn’t sound good.
You can buy me a beer or simply donate to LE: Support Encryption for Everyone - Let's Encrypt
I gave you a starting point entry earlier:
Don't forget to mark this topic "solved".
should I maybe change this and enter it in cron like this?
41 */12 * * * /usr/local/sbin/certbot-auto renew --apache --deploy-hook '/etc/init.d/apache2 restart'
When run with “-q” it will only “renew”…So they are basically the same.
If you want to go ALL OUT (or ALL IN) use:
renew -n -q
41 */12 * * * /usr/local/sbin/certbot-auto renew -n -q --apache --deploy-hook '/etc/init.d/apache2 restart'
Just out of curiosity, does this crone command ecexute every day at every 12 hours on the 41st minute ?
YES
00:41 & 12:41
everyday
Thank you a lot again!
You can thank me in 2 days when it renews your first cert (automatically) - LOL
Or, better yet, thank LE (for all they do)
Yes definitely will donate again and thanks to every one of you working for all of us here, it is really appreciated around the globe. Hope you realize that.
I added the cron job using crontab -e
got this
crontab -e
no crontab for root - using an empty one
GNU nano 2.7.4 File: /tmp/crontab.IynLJ2/crontab Modified
daemon’s notion of time and timezones.
Output of the crontab jobs (including errors) is sent through
email to the user the crontab file belongs to (unless redirected).
For example, you can run a backup of all your user accounts
at 5 a.m every week with:
0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
For more information see the manual pages of crontab(5) and cron(8)
m h dom mon dow command
41 */12 * * * /usr/local/sbin/certbot-auto renew --apache --deploy-hook ‘/etc/init.d/apache2 restart’
Added this
I hate to bother you again, but I waited for 00:41 just to see if the job will run and if everything will be alright, and the job did not run
Can we check it somehow ?
I used the command crontab -e
it was first time using it so I selected nano editor
I added the following code
It created the new cron
crontab: installing new crontab
Also when I run systemctl list-timers -all
NEXT LEFT LAST PASSED UNIT
Fri 2019-11-08 01:09:00 UTC 13min left Fri 2019-11-08 00:39:01 UTC 16min ago phpsessionclean.timer
Fri 2019-11-08 06:08:13 UTC 5h 12min left Thu 2019-11-07 21:01:59 UTC 3h 53min ago apt-daily.timer
Fri 2019-11-08 06:11:31 UTC 5h 15min left Thu 2019-11-07 06:04:35 UTC 18h ago apt-daily-upgrade.timer
Fri 2019-11-08 14:47:11 UTC 13h left Thu 2019-11-07 14:47:11 UTC 10h ago systemd-tmpfiles-clean.ti
this is all of them from before, I suspect my cron should have been added ?
Thank you again sorry for bothering.
