Anthon
December 14, 2022, 11:07pm
1
I have been unable to obtain cert renewal automatically. Manual renewal works great.
There appears to be a conflict because the system's init is systemd.
The latest attempt to fix the daily cron job to renew automatically is show below. The file is a mess.
I would appreciate any assistance. Thanks!
System Description:
Ubuntu 22.04 LTS (Web server, Reverse Proxy and IPTables firewall)
Apache2 2.4.52
Init System: systemd
I have full direct system access to system
root@genesis:/etc/cron.d# cat certbot
#/etc/cron.d/certbot: crontab entries for the certbot package
#Upstream recommends attempting renewal twice a day
#Eventually , this will be an opportunity to validate certificates
#haven 't been revoked, etc. Renewal will only occur if expiration
#is within 30 days.
#Important Note! This cronjob will NOT be executed if you are
#running systemd as your init system. If you are running systemd,
#the cronjob.timer function takes precedence over this cronjob. For
#more details, see the systemd.timer manpage, or use systemctl show
#certbot .timer.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
0 */12 * * * root test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e 'sleep int(rand(43200))' && certbot -q renew
root@genesis:/etc/cron.d# ls -l
MikeMcQ
December 14, 2022, 11:43pm
2
A couple things. If you got your cert with a --manual method it cannot be automated. There is no way to automate manual actions.
And, most Linux systems are systemd so that by itself is not a problem. Usually those systems have a timer instead of a cron job. See (this link ) for how to check for that and more details.
We can figure this out. The best place to start is to show us the contents of the conf file for this cert in this folder
/etc/letsencrypt/renewal
_az
December 15, 2022, 12:07am
3
If there are multiple cron or systemd timers jobs installed it's generally OK, because one will succeed and the others will do nothing.
What would be helpful is the error output, from a command like:
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin certbot renew --dry-run
Buffalo
December 15, 2022, 12:13am
4
I had a problem with running ./acme.sh by hand succeeding, but failing if invoked via cron (or a systemd timer). Turned out that the environment differed, and it was solved by adding environment into the cron invocation along the lines of
#!/bin/bash
NSUPDATE_SERVER=192.168.1.2 NSUPDATE_KEY=pwd/okiefrog.key ./acme.sh
in a script invoked via cron. As a old stubborn fellow, I find systemd timers to be abominable and regularly stomp them out of existence ...
Anthon
December 15, 2022, 1:16am
5
Hi MikeMcQ
per your request:
root@genesis:/etc/letsencrypt/renewal# cat allenintech.com-0002.conf
#renew_before_expiry = 30 days
version = 1.31.0
archive_dir = /etc/letsencrypt/archive/allenintech.com-0002
cert = /etc/letsencrypt/live/allenintech.com-0002/cert.pem
privkey = /etc/letsencrypt/live/allenintech.com-0002/privkey.pem
chain = /etc/letsencrypt/live/allenintech.com-0002/chain.pem
fullchain = /etc/letsencrypt/live/allenintech.com-0002/fullchain.pem
#Options used in the renewal process
[renewalparams]
account = 167f86e1432ceed045ef851b5bae590f
authenticator = apache
installer = apache
key_type = rsa
MikeMcQ
December 15, 2022, 1:33am
6
Thanks. And why do you think renewal is not working?
Because the cert for that domain was issued on Nov2 and would not renew until early January
Also, when we see '-0002' in the cert name it often points to problems with Apache config.
What does the command certbot certificates show?
Rip
December 15, 2022, 1:46am
7
Thanks for the info...
Could you share the output of:
openssl x509 -noout -dates -in /etc/letsencrypt/live/allenintech.com-0002/cert.pem | grep -e "notBefore" -e "notAfter="
My inquiry is based on @MikeMcQ comment:
Rip
December 15, 2022, 1:47am
8
(It is possible that the symlinks are hosed.)
Anthon
December 15, 2022, 2:08am
9
To get the cert I had to issue CLI commands: certbot renew or certbot --apache. For the past several years I have only issued those commands. Years ago I issued a command that has now been deprecated. -0002 is not recent. It has been that way for years.
The next time the cert is due in January, I would like to have the cron file working. If it does not work, then I'll issue cerbot renew or certbot --apache.
Anthon
December 15, 2022, 2:11am
10
@Rip
The output
/etc/letsencrypt/renewal# openssl x509 -noout -dates -in /etc/letsencrypt/live/allenintech.com-0002/cert.pem | grep -e "notBefore" -e "notAfter="
notBefore=Nov 2 02:06:18 2022 GMT
notAfter=Jan 31 02:06:17 2023 GMT
Rip
December 15, 2022, 2:18am
11
So the output doesn't show a renewal due yet. It is coming though, and you are wanting to "prebug" your cron or system timers... Yes?
Anthon
December 15, 2022, 2:34am
12
Here are the results. All other sites were taken out of the system, except the following:
allenintech.com (reachable with cert)
nextcloud.allenintech.com (reachable with cert)
kibana.alleninech.com (reachable with cert)
elasticsearch.allenintech.com (purposely not reachable)
I used certbot renew and certbot --apache to obtain the certs. I do not stop apache2.
RESULTS OF YOUR REQUEST. Thanks!
Processing /etc/letsencrypt/renewal/actngop.org-0001.conf
Simulating renewal of an existing certificate for actngop.org and www.actngop.org
Failed to renew certificate actngop.org-0001 with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
Processing /etc/letsencrypt/renewal/actngop.org.conf
Renewal configuration file /etc/letsencrypt/renewal/actngop.org.conf is broken.
The error was: expected /etc/letsencrypt/live/actngop.org/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/allenintech.com-0001.conf
Simulating renewal of an existing certificate for www.allenintech.com and allenintech.com
Failed to renew certificate allenintech.com-0001 with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
Processing /etc/letsencrypt/renewal/allenintech.com-0002.conf
Simulating renewal of an existing certificate for allenintech.com
Processing /etc/letsencrypt/renewal/allenintech.com.conf
Renewal configuration file /etc/letsencrypt/renewal/allenintech.com.conf is broken.
The error was: expected /etc/letsencrypt/live/allenintech.com/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/gitlabrunner.allenintech.com-0001.conf
Simulating renewal of an existing certificate for gitlabrunner.allenintech.com and www.gitlabrunner.allenintech.com
Failed to renew certificate gitlabrunner.allenintech.com-0001 with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
Processing /etc/letsencrypt/renewal/gitlabrunner.allenintech.com.conf
Renewal configuration file /etc/letsencrypt/renewal/gitlabrunner.allenintech.com.conf is broken.
The error was: expected /etc/letsencrypt/live/gitlabrunner.allenintech.com/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/gitlabserver.allenintech.com-0001.conf
Simulating renewal of an existing certificate for gitlabserver.allenintech.com and www.gitlabserver.allenintech.com
Failed to renew certificate gitlabserver.allenintech.com-0001 with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
Processing /etc/letsencrypt/renewal/gitlabserver.allenintech.com.conf
Renewal configuration file /etc/letsencrypt/renewal/gitlabserver.allenintech.com.conf is broken.
The error was: expected /etc/letsencrypt/live/gitlabserver.allenintech.com/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/guacamole.allenintech.com.conf
Simulating renewal of an existing certificate for guacamole.allenintech.com and www.guacamole.allenintech.com
Domain: guacamole.allenintech.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for guacamole.allenintech.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for guacamole.allenintech.com - check that a DNS record exists for this domain
Domain: www.guacamole.allenintech.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.guacamole.allenintech.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.guacamole.allenintech.com - check that a DNS record exists for this domain
Failed to renew certificate guacamole.allenintech.com with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/hishandstn.org.conf
Renewal configuration file /etc/letsencrypt/renewal/hishandstn.org.conf is broken.
The error was: expected /etc/letsencrypt/live/hishandstn.org/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/kibana.allenintech.com.conf
Simulating renewal of an existing certificate for kibana.allenintech.com
Failed to renew certificate kibana.allenintech.com with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
Processing /etc/letsencrypt/renewal/nextcloud.allenintech.com-0001.conf
Simulating renewal of an existing certificate for nextcloud.allenintech.com and www.nextcloud.allenintech.com
Processing /etc/letsencrypt/renewal/nextcloud.allenintech.com.conf
Renewal configuration file /etc/letsencrypt/renewal/nextcloud.allenintech.com.conf is broken.
The error was: expected /etc/letsencrypt/live/nextcloud.allenintech.com/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/tomcat.allenintech.com.conf
Simulating renewal of an existing certificate for tomcat.allenintech.com and www.tomcat.allenintech.com
Domain: tomcat.allenintech.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for tomcat.allenintech.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for tomcat.allenintech.com - check that a DNS record exists for this domain
Domain: www.tomcat.allenintech.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.tomcat.allenintech.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.tomcat.allenintech.com - check that a DNS record exists for this domain
Failed to renew certificate tomcat.allenintech.com with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/www.actngop.org.conf
Renewal configuration file /etc/letsencrypt/renewal/www.actngop.org.conf is broken.
The error was: expected /etc/letsencrypt/live/www.actngop.org/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/www.elasticsearch.allenintech.com.conf
Simulating renewal of an existing certificate for www.elasticsearch.allenintech.com and elasticsearch.allenintech.com
Failed to renew certificate www.elasticsearch.allenintech.com with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
Processing /etc/letsencrypt/renewal/www.kibana.allenintech.com.conf
Simulating renewal of an existing certificate for kibana.allenintech.com and www.kibana.allenintech.com
The following simulated renewals succeeded:
/etc/letsencrypt/live/allenintech.com-0002/fullchain.pem (success)
/etc/letsencrypt/live/nextcloud.allenintech.com-0001/fullchain.pem (success)
/etc/letsencrypt/live/www.kibana.allenintech.com/fullchain.pem (success)
The following simulated renewals failed:
/etc/letsencrypt/live/actngop.org-0001/fullchain.pem (failure)
/etc/letsencrypt/live/allenintech.com-0001/fullchain.pem (failure)
/etc/letsencrypt/live/gitlabrunner.allenintech.com-0001/fullchain.pem (failure)
/etc/letsencrypt/live/gitlabserver.allenintech.com-0001/fullchain.pem (failure)
/etc/letsencrypt/live/guacamole.allenintech.com/fullchain.pem (failure)
/etc/letsencrypt/live/kibana.allenintech.com/fullchain.pem (failure)
/etc/letsencrypt/live/tomcat.allenintech.com/fullchain.pem (failure)
/etc/letsencrypt/live/www.elasticsearch.allenintech.com/fullchain.pem (failure)
Additionally, the following renewal configurations were invalid:
/etc/letsencrypt/renewal/actngop.org.conf (parsefail)
/etc/letsencrypt/renewal/allenintech.com.conf (parsefail)
/etc/letsencrypt/renewal/gitlabrunner.allenintech.com.conf (parsefail)
/etc/letsencrypt/renewal/gitlabserver.allenintech.com.conf (parsefail)
/etc/letsencrypt/renewal/hishandstn.org.conf (parsefail)
/etc/letsencrypt/renewal/nextcloud.allenintech.com.conf (parsefail)
/etc/letsencrypt/renewal/www.actngop.org.conf (parsefail)
8 renew failure(s), 7 parse failure(s)
Anthon
December 15, 2022, 2:37am
13
Yes, That is correct. I want to "prebug" the cron or system timers so the next time the cert is due the cron will work.
Thanks!
Anthon
December 15, 2022, 2:39am
14
It is possible the symlinks are hosed. How would I fix them?
Anthon
December 15, 2022, 2:41am
15
The cron file says
#certbot .timer.
I am running systemd
Rip
16
OK so let me have a minute. I have seen this before and I can't remember who gave the fix but let me look in my "bag".... Let's look at the symlink(s) first.
Anthon
December 15, 2022, 2:45am
17
I appreciate the insight. I'll keep that in mind. Thanks!
Rip
December 15, 2022, 2:47am
18
@Buffalo is excellent. Much knowledge there.
Anthon
December 15, 2022, 2:52am
19
OK. I have certs for sites
allenintech.com
I do not need the certs for the other sites such as guacamole.allenintech.com , etc.
I am trying to trouble shoot cron so that in January the certs are renewed automatically by cron.
Rip
December 15, 2022, 2:58am
20
Ok fine. But would you show the output of
ls -la -R /etc/letsencrypt/
It will show the regular files and symlinks (which may need to be repaired.)
You may not need them now, but you will in the near future.
