But it always prompts the finial confirmation blue window, says " Your existing certificate has been successfully renewed, and the new certificate has been installed. You should test your configuration at: www.ssllabs.com/xxxxx". And stop proceeding the following commands.
How can I bypass this dialog? Looked the letsencrypt-auto --help all, but not found the switch to turn this off. I do not want to use webroot plugin and config file.
Thanks for the help.
Thanks for the reply.
This command still needs to choose 'how would like to authenticate with the Let's enrypt Ca?, Apache or standalone'.
So the working command for me is,
