First, using the renew command fails in various ways, which is unacceptable when 1000s of certs require renewing, as renew increments all cert file numbers each renewal, so if renew is used, each host/domain Apache config must be modified to match incremented file numbers. Ugly for 1000s of certs.
You’d think, issuing the certonly command again would be sufficient. Nope. This results in an interactive prompt…
What would you like to do?
1: Keep the existing certificate for now
This is unacceptable too. Imagine typing “2” for 1000s of hosts + domains. Ugly…
Using --non-interactive with certonly is badly broken also. This results in a NOP + incorrect message…
Certificate not yet due for renewal; no action taken.
What seems to work is a brute force approach, as follows.
Rifle through all certs + find the ones about to expire. I suggest using a 30 day window to reduce
all the masses of email you’ll get about expiring certs. This email seems to start around day 20-30. -
Once located, for each host/domain, delete all traces of /etc/letsencrypt files associated with host/domain.
If error, restore all /etc/letsencrypt files + notify interested parties manual intervention is required for this host/domain.
All files must be restored, else Apache will fail to start during restarts, as happens nightly with logrotate.
- Do service apache reload (or your distro’s equivalent).
- Test site link with curl -I -L $URL.
All this is ridiculous overkill, which could be fixed by fixing letsencrypt-auto to work sensibly, meaning if certonly is issued against existing cert, then allow --renew-replace flag or some other flag to auto answer “2” (renew + replace cert).
