How setting up SSL on Xampp (Ubuntu)
Hello?
I run my site using Ubuntu 20.04 and Xampp on a server based on Conoha.
I tried to get an SSL certificate and apply it to my site, but most of the information was not subject to the condition Ubuntu + Xampp.
I want to know how to get SSL issued under the condition of Ubuntu 20.04+Xampp and apply it to my site. I can't find the relevant information.
Please help me.
Hi @MAYUI, and welcome to the LE community forum :slight_smile:
You may do better by splitting those two things:
  • get a cert using an ACME client for Ubuntu 20 [Like: certbot via snap]
  • update Xampp to use the obtained cert
I run a homepage using XAMPP at Ubuntu 20.04. When I used the following command to get the ssl certificate, the following error occurred. I need a cause of this and a solution. I beg you.
My domain is: www.waggle.kr
I ran this command: sudo certbot certonly --webroot -w /opt/lampp/htdocs/w -d www.waggle.kr
http-01 challenge for www.waggle.kr
    Domain: www.waggle.kr
    Detail: (my ip): Invalid response from
    http://www.waggle.kr/.well-known/acme-challenge/(#^%$^$#$#)
    404
  • Your account credentials have been saved in your Certbot
The operating system my web server runs on is (include version): ubuntu 20.04 + XAMPP
My hosting provider, if applicable, is: conoha
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Can you locate the file with the Apache VirtualHost config for this domain name?
Inside that VirtualHost, what is the folder name for the DocumentRoot ?
The DocumentRoot folder should be used for the -w folder
I think you may need to remove the /w from the end of the folder in your certbot -w but best to see what your DocumentRoot says to make sure
I was able to find the file with the virtual host in /opt/lampp/etc/extra/httpd-vhost.conf, and the contents are as follows:
<VirtualHost *:80>
    ServerAdmin (E-mail)
    DocumentRoot "/opt/lampp/htdocs/w/"
    ServerName waggle.kr
    ServerAlias www.waggle.kr
    ErrorLog "logs/waggle.kr-error_log"
    CustomLog "logs/waggle.kr-access_log" common
</VirtualHost>
That looks right. Can you show output of this command?
apachectl -S
Command 'apachectl' not found, but can be installed with:
apt install apache2
It comes out like this. It's not that I didn't install Apache 2, but it seems to be because the Apache is embedded in xampp.
And here's the news. As you recommended, I took out "W" and used the command "sudo certbot certonly --webroot -w /opt/lampp/htdocs -d www.waggle.kr" and the certificate was issued.
Now I wonder what I should do to apply the certificate.
No, I understand. I was hoping the same command would work anyway.
I am a little puzzled why removing the /w worked. Your DocumentRoot showed it needed one. I wanted to see that other -S info as I wonder if you have more than one VirtualHost for the same domain name.
I originally saw you redirected requests to your domain name to a URL that had a /w on the end. That was why I thought it would not be in your DocumentRoot but it was. Puzzling
I don't know the xampp environ well (as you can see), so can't help much with configuring apache inside it. Sorry
If you can find the command that will show output from -S I could maybe help
Please show the output of:
netstat -pant | grep 80
Also, this could use an update:
