Help to get ssl and config for a subdomain in xampp
Hi
I try to get ssl to my subdomain that set on xampp apachi webserver.
I use wacs.exe v2.0.7.315 for get ssl but it not work
what should i do?
how can i get ssl for my subdomain and how to config it on xampp?
its important for me. Thanks.
Hi @vincentfplunk
please answer the following questions. That’s the standard template of #help
My domain is: site.com
I ran this command: in cmd>wacs.exe>M>1>subdomain.site.com>2 manualy create record>2>3>c:\crtificate>3>1>email@site.com>n>y>“add TXT code in domain panel”>_acme-challenge.subdomain.site.com
after that it not work
It produced this output: haven’t output
My web server is (include version): xampp apache
The operating system my web server runs on is (include version): win server 2016
My hosting provider, if applicable, is: deticate server
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): ?
Your domain name is required if you have trouble using dns-01 validation.
Wrong place, wrong entry - there are a lot of errors possible.
I dont like to show my domain name to all and i change my domain name with a simple to send in in this topic.
I know i have wrong entry or other wrongs.
Can u help me to get ssl for my subdomain and config it?
If you go to the github page for wacs, you'll see a link to a patreon page proposing just what you want.
You can use my online tool to check your DNS TXT entries ( https://check-your-website.server-daten.de/ ). That checks typical errors with these _acme-challenge - entries. Check the part "9. TXT".
