Error after entering certificate issue command
I run a homepage using XAMPP at Ubuntu 20.04. When I used the following command to get the ssl certificate, the following error occurred. I need a cause of this and a solution. I beg you.
My domain is: www.waggle.kr
I ran this command: sudo certbot certonly --webroot -w /opt/lampp/htdocs/w -d www.waggle.kr
http-01 challenge for www.waggle.kr
    Domain: www.waggle.kr
    Detail: (my ip): Invalid response from
    http://www.waggle.kr/.well-known/acme-challenge/(#^%$^$#$#)
    404
  • Your account credentials have been saved in your Certbot
The operating system my web server runs on is (include version): ubuntu 20.04 + XAMPP
My hosting provider, if applicable, is: conoha
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
2 posts were merged into an existing topic: How setting up SSL on Xampp (Ubuntu)
