How long I got block from invalid authorization?
I tried multiple time configure the nginx and then I got block from multiple authentication
I have chmod 777 -R /home already
My IP address also bind to A Record already. At least customer claims that
What is wrong with my configuration?
Here is my /etc/nginx/site-enable/cmoc
upstream app {
   server localhost:8000;
   listen 80;
   root /home/web/cmoc-web;
   server_name cmoc.beenets.com;
           proxy_pass_request_headers on;
           proxy_set_header           Host $host;
 	   proxy_set_header           X-Forwarded-Proto $scheme;
           proxy_pass                 http://app;
   location ~ /.well-known{
	   allow all;
/etc/nginx/nginx.conf
user www-data;
worker_processes 4;
pid /run/nginx.pid;
events {
	worker_connections 768;
http {
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	gzip on;
	gzip_disable "msie6";
certbot-auto certonly -a webroot --webroot-path=/home/web/cmoc-web -d cmoc.beenets.com
An unexpected error occurred:
There were too many requests of a given type :: Error creating new authz :: Too many invalid authorizations recently.
I guess that you should wait a hour... From https://letsencrypt.org/docs/rate-limits/:
We recently (April 2017) introduced a Failed Validation limit of 5 failures per account, per hostname, per hour. This limit will be higher on staging so you can use staging to debug connectivity problems.
:confused:
HIH!
Andreyev
Hi Sarit,
The rate limit documentation page says:
So the answer is 1 hour. You should also try using the staging environment while you iron out your issuance trouble.
Thank you andreyev and cpu. I have been using LE for a couple of months.
This is up2date information for me.
