How to avoid "Too many failed authorizations recently"?
Hi, I was trying to set up a certificate for one of my domains, but it kept failing and I tried some different things to fix it. But now when I try this:
certbot certonly --webroot -w /home/www-root -d mydomain.com -d www.mydomain.com
I get the following error:
An unexpected error occurred:
There were too many requests of a given type :: Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/
Could I have avoided this failed auth limit if I added --dry-run to my command line above after certonly?
I’m hoping this will clear up in an hour and not a week because my site is currently without an SSL certificate. Thanks!
Hi @MontyHu,
Yes, using --dry-run switch you are using staging server and this test server has higher rate limits.
Yes, that limit stands just for 1 hour.
Cheers,
sahsanu
Thank you, got the certificates issued and working now!
