Continuing the discussion from Public beta rate limits:
Could it be that your CI box is hitting staging, but your dev box is hitting prod?
Just confirmed, the CI server is talking to staging, for example, here is the Identifier status URI for the most recent run (just moments ago):
https://acme-staging.api.letsencrypt.org/acme/authz/y2zQ92UptY5ApMNMG6hIfDFlpgA6_NcEGblnnU3hshU
I also did go through the most recent dozen or so CI runs and also confirmed that they were all built on the same build box, so it would have presented the same same IP address to LE each time.
Well it took a little while, but now I’m hitting the same rate limit in dev as well as the CI server.
