My domain is: customserver.me
I ran this command: sudo certbot --apache -d customserver.me -d www.customserver.me
austin@mc:~$ sudo certbot --apache -d customserver.me -d www.customserver.me
http-01 challenge for customserver.me
http-01 challenge for www.customserver.me
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. customserver.me (http-01): urn:ietf:params:a cme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://customserver.me/.well-known/acme-challenge/ll O5TDCX0nM6ps2MNwBxBHotkDX03lFEXyk0qMea7aU: Timeout during connect (likely fi rewall problem), www.customserver.me (http-01): urn:ietf:params:acme:error:c onnection :: The server could not connect to the client to verify the domain :: Fetching http://www.customserver.me/.well-known/acme-challenge/JJa1NH1ex LUQgzimrBl7Qr_D1SKcmFsa_1Wo9_9JI90: Timeout during connect (likely firewall problem)
Domain: customserver.me
Type: connection
Detail: Fetching
http://customserver.me/.well-known/acme-challenge/llO5TDCX0nM6ps2MNwBxBHo tkDX03lFEXyk0qMea7aU:
Timeout during connect (likely firewall problem)Domain: www.customserver.me
Type: connection
Detail: Fetching
http://www.customserver.me/.well-known/acme-challenge/JJa1NH1exLUQgzimrBl 7Qr_D1SKcmFsa_1Wo9_9JI90:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
client. If you’re using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
My web server is (include version):apache2.4.29
The operating system my web server runs on is (include version):Xubuntu 18.04
using Certbot): certbot 0.31.0
I am extremely new to SSL please go easy on me.
