Help with ssl certificate error. please
Hi I wake up with This site can’t provide a secure connection
worldclasscrew.com sent an invalid response.
  • [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
    ERR_SSL_PROTOCOL_ERROR
The index.html site is ok
Befor that I got awstats there
My domain is: worldclasscrew.com
apachectl -t -D DUMP_VHOSTS
port 80 namevhost worldclasscrew.com (/etc/httpd/conf.d/m_vhost.conf:1)
port 443 namevhost worldclasscrew.com (/etc/httpd/conf.d/m_vhost-le-ssl.conf:2)
Also run certbot -d worldclasscrew.com and tried 1 - to reinstall the same certificate with no different results , 2 - to reinstall a new certificate with no different results
The certificate is valid
Virtualization: kvm
Operating System: CentOS Linux 7 (Core)
CPE OS Name: cpe:/o:centos:centos:7
Kernel: Linux 3.10.0-1062.4.1.el7.x86_64
Architecture: x86-64
The version of my client is: certbot 0.39.0
Hi @eli.za,
What is the result you’re wishing to achieve? Are you expecting to see your awstats page?
Can you post the full contents of these vhosts please?
  • /etc/httpd/conf.d/m_vhost.conf
  • /etc/httpd/conf.d/m_vhost-le-ssl.conf
I see that the certificate is valid and is explicitly for worldclasscrew.com, not www.worldclasscrew.com.
$ echo | openssl s_client -connect worldclasscrew.com:443 -servername worldclasscrew.com -verify_hostname worldclasscrew.com 2>&1 | openssl x509 -noout -text | grep -E '(CN|DNS)'
        Issuer: C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
        Subject: CN = worldclasscrew.com
                DNS:worldclasscrew.com
ok i delete the config file
What OS are you attempting to connect to the website from? I am showing successful connections from a Fedora 31 virtual machine.
This shows the redirect from HTTP to HTTPS working successfully
$ curl -IL worldclasscrew.com
Date: Thu, 19 Dec 2019 15:03:06 GMT
Server: Apache/2.4.41 (codeit) OpenSSL/1.1.1d
HTTP/2 200
date: Thu, 19 Dec 2019 15:03:06 GMT
server: Apache/2.4.41 (codeit) OpenSSL/1.1.1d
strict-transport-security: max-age=63072000; includeSubdomains;
x-frame-options: SAMEORIGIN
last-modified: Thu, 19 Dec 2019 10:55:40 GMT
etag: "22-59a0c66ea1f97"
accept-ranges: bytes
content-length: 34
vary: User-Agent
cache-control: private, must-revalidate
content-type: text/html; charset=UTF-8
This shows retrieving the contents of the website successfully.
$ curl -L worldclasscrew.com
welcome - please come back in 2 h
Im trying to connect from win 10 , google chrome last version
Can you clear your cache, use private mode, or even try a different browser to see if those connect successfully?
I E it says This might be because the site uses outdated or unsafe TLS security settings. If this keeps happening, try contacting the website’s owner.
Your TLS security settings aren’t set to the defaults, which could also be causing this error…
don t know what to think
cleared the cache , tried in IE, private mode , firefox … same thing . yestday was fine, no error
sooy for not showing the cookie section ,don’ t get the printscreen is says noo cookies and the red sign on it
Do you happen to run any third party antivirus on your computer such as Avast, ESET, Kaspersky, etc?
Can you show me the certificate details in Chrome and IE when you receive the error? It should look similar to this picture:
got the extension , thats ok is shows as in your image , the only thing i got I can t access the website and I don t know why ?? is like crazy . are you able to see the site at your end , just checking
Yes I am. I can see it in a browser and via curl requests.
okay thats great, good to know
At this point I think we’ve narrowed down the problem to be your host machine. I don’t have any recommendations for getting that fixed though. Best of luck with it.
