Help with new cert on selfhosted ubuntu where port 80 is blocked
#1
I’ve previously had a certificate that I validated on port 443 before that approach was removed. Since it was just renewing since then, it was fine until I did a new install to upgrade to 18.04. I didn’t properly backup letsencrypt so I have been trying to re-certify. I have no-ip for the domain dns, and can add TXT DNS entries but that doesn’t seem to be an option anymore. Any suggestions?
andamp13.hopto.org
sudo ./certbot-auto certonly --standalone --preferred-challenges tls-sni -d andamp13.hopto.org
sudo certbot certonly --standalone --preferred-challenges dns -d andamp13.hopto.org
and other variations
either: timed out trying to connect for port 80 solutions, or no valid verification for this host. (paraphrasing)
nginx
ubuntu server 18.04
self, on an IPS that blocks port 80.
Yes
No
#2
Hi @rebootd
tls-sni-01 - validation is deprecated and will be deactivated. See
https://community.letsencrypt.org/t/february-13-2019-end-of-life-for-all-tls-sni-01-validation-support/74209/2
The dns-01 - validation should work, if you don’t have an open port 80. But not with --standalone, use instead (first time) --manual.
Or check if your dns provider supports an API you can use.
Perhaps acme.sh is an option. There are > 50 dns provider supported.
#3
Thanks! I have no issue switching dns providers if you know of recommendations? I just picked one that my router supports for dynamic updates, but I can run that on my server too.
#4
