I’ve been using letsencrypt-auto forever and a day on my Ubuntu box at home. Ubuntu 16 lts. For the past year, at least. Port 80 is blocked and has been blocked forever and a day too, but I “was” able to Let’s Encrypt to get a certificate. It worked flawlessly. Now I can no longer get a certificate to install. 443 is and always has been open. What’s going wrong? What do I need to do? I’ve got 9 days. Please help. Why did it suddenly stop working? What did I miss?
if you have an old configuration, then you have used tls-sni-01 - validation via port 443.
But tls-01-validation is deprecated, support ends 2019-02-13.
So you must switch to http-01 - validation, this requires an open port 80.
Or you use dns-01 - validation, then a dns txt entry is required.
Also, some ACME clients support the new port 443 challenge type, TLS-ALPN-01, but Certbot doesn't.
@JuergenAuer's and @mnordhoff's comments are both completely correct.
The announcements of the changed behavior on this forum are at
and the underlying motivation is the TLS-SNI-01 end-of-life announcement that @JuergenAuer linked to (which would cause a more abrupt failure in mid-February if we didn't take steps to switch people over before then).
As @erica mentioned in the former post,
Between November and February (when the TLS-SNI-01 challenge type is deprecated at the server end ), users who have been relying on TLS-SNI-01 can use the flag
--preferred-challenges tls-sni-01as a temporary patch to get a certificate quickly, before correcting the configuration.
So you might want to do this now and then investigate DNS challenge options or a client that supports TLS-ALPN-01 before February 19.
Are the below errors related? I’m trying the new/suggestion option, and I have a simple redirect in the Apache httpd.conf file. This is on Fedora 29, certbot is version 0.29.1
<VirtualHost *:80>
ServerName kopernik.dsm.fordham.edu
ServerAlias kopernik.dsm.fordham.edu
Redirect permanent / https://kopernik.dsm.fordham.edu/
</VirtualHost>
certbot renew --debug --dry-run --preferred-challenges http-01,dns-01
Processing /etc/letsencrypt/renewal/kopernik.dsm.fordham.edu.conf
http-01 challenge for kopernik.dsm.fordham.edu
Attempting to renew cert (kopernik.dsm.fordham.edu) from /etc/letsencrypt/renewal/kopernik.dsm.fordham.edu.conf produced an unexpected error: Failed authorization procedure. kopernik.dsm.fordham.edu (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://kopernik.dsm.fordham.edu/.well-known/acme-challenge/uXy6Fs_AT0LZHtXpEDnJQyBCuxNR_Ye5pr8e7MTXmjI: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/kopernik.dsm.fordham.edu/fullchain.pem (failure)
Exiting abnormally:
File "/usr/bin/certbot", line 11, in <module>
load_entry_point('certbot==0.29.1', 'console_scripts', 'certbot')()
File "/usr/lib/python3.7/site-packages/certbot/main.py", line 1352, in main
File "/usr/lib/python3.7/site-packages/certbot/main.py", line 1259, in renew
renewal.handle_renewal_request(config)
File "/usr/lib/python3.7/site-packages/certbot/renewal.py", line 457, in handle_renewal_request
len(renew_failures), len(parse_failures)))
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
Domain: kopernik.dsm.fordham.edu
Type: connection
Detail: Fetching
Yes, it seems like a firewall or router is indeed blocking port 80 connections to this machine from outside of your network.
Am I seeing double (or is there a reason to relist the same name)?
Also, does this redirect all requests to https://kopernik.dsm.fordham.edu/
or does it allow for the full path to remain?
So that:
http://kopernik.dsm.fordham.edu/.well-known/acme-challenge/uXy6F...
goes to:
https://kopernik.dsm.fordham.edu/.well-known/acme-challenge/uXy6F...
NOT to:
Those are both great things to double-check in the configuration, but I’m pretty sure that neither of them is causing the immediate problem (since we have a connection timeout rather than connection refused or incorrect validation content returned).
