I must migrate a site from another hosting to my VPS. The site is currently on cpanel hosting and secured with their cerificate.
I want to secue it with Let’s Encrypt after the migration. Do I do that like with any other site, since the cpanel autority’s certificate is still valid?
Will it produce and problems if I just get a new certificate via certbot on the new VPS?
if you use cPanel, it’s the best to use the cPanel-Letsencrypt-Plugin.
I don’t know what this plugin is doing. But one more certificate doesn’t hit any limit of Letsencrypt. So it’s the best way to create a new certificate.
You can use Certbot. But if you have already cPanel, use the cPanel-Plugin.
Then you can use Certbot to get a new certificate. You can create 5 certificates with the same names in one week. So one new certificate isn't a problem.
There can be any number of simultaneously valid certificates from any number of different CAs for the same domain name. The certificates don't contradict or invalidate one another.
