how do I do all of that
You don't know how to do any of those things?
well for the first step I assume that I've already done it (refer to the picture I posted above in the thread);
I'm pretty sure that ports 80 and 443 are allowed (used both ufw and iptables);
Nginx should be listening to port 80 and 443, I didn't touch the configuration after running
sudo openssl --nginx
I don't know what "SSL on" means.
I guess the "how do I do all of that" was just a request for explicit instructions in case I had done something incorrectly
Ok the first two seem to have been taken care of.
Let's focus on the third:
Let's have a look at your nginx
config.
Please upload the output of:
sudo nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip.conf:
load_module modules/ngx_stream_geoip_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/alessandroveller.xyz:
server{
server_name alessandroveller.xyz;
root /var/www/alessandroveller;
index index index.html test main;
try_files $uri $uri/ =404;
ssl_certificate /etc/letsencrypt/live/alessandroveller.xyz/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/alessandroveller.xyz/privkey.pem; # managed by Certbot
server{
if ($host = alessandroveller.xyz) {
} # managed by Certbot
listen 80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
Do you have a SECOND PC with a web browser on your network? If you do then you should be able to run tests from there. Get your router completely out of the picture for starters.
This is what i think you should do:
Setup your second PC (windows is fine) and put your webserver name in it's hosts files.
Wipe your webserver and start over (no telling what you have messed up with by now on it)
Get your webserver setup to where you can surf port 80 on it from your second PC
run certbot by the book and configure your webserver for SSL. Verify you can surf both the regular http and the ssl https port from your second PC
If you can't do all of this then no amount of messing around with port forwards on your router is going to do squat.
Once you get all that working THEN setup the port forwards on your router and see if you can access your webserver from the Internet. You can do this yourself from one of the many website testers out there like the w3c tester
Obviously if you don't want to tear into your server you can try this without doing that.
UPDATE: I tried installing nginx and certbot on my (arch linux) laptop out of all thing and IT WORKED at my first attemp! So I guess that the issue must be with my desktop, maybe something that I disabled in the BIOS long ago? I can't find an explanation as to why it wouldn't work
