Could you please check the firewall status (both your internal and external firewall) for the server?
It seems that there’s a firewall filtered all the connections to port 443, port 80 is open on your machine.
Thanks for the prompt reply, my site is a subdomain of kp,gov.pk, does it matter if they have a firewall enabled? Because i dont have any firewall enabled yet
