Help with DNS configuration
lern2code.com
sudo certbot -v --apache
[Additional output omitted]
Domain: lern2code.com
Type: dns
Detail: DNS problem: query timed out looking up A for lern2code.com; DNS problem: query timed out looking up AAAA for lern2code.com
---- I am hosting my own DNS server and it looks like it isn't right. Any help is appreciated.
Server version: Apache/2.4.52 (Ubuntu)
Ubuntu 22.04.3 LTS
Self hosted
Yes
No
certbot 2.8.0
Hello @Torp, welcome to the Let's Encrypt community. :slightly_smiling_face:
Your DNS system seems poor.
https://unboundtest.com/m/CAA/lern2code.com/6MJDZ4UJ the tail end
Jan 12 00:23:12 unbound1.19[321343:0] debug: EDNS lookup known=0 vs=0
Jan 12 00:23:12 unbound1.19[321343:0] debug: serviced query UDP timeout=6016 msec
Jan 12 00:23:12 unbound1.19[321343:0] debug: inserted new pending reply id=5f45
Jan 12 00:23:12 unbound1.19[321343:0] debug: opened UDP if=0 port=41465
Jan 12 00:23:12 unbound1.19[321343:0] debug: comm point start listening 9 (-1 msec)
Error running query: read udp 127.0.0.1:43255->127.0.0.1:1053: i/o timeout
And using the online tool Let's Debug yields these results
https://letsdebug.net/lern2code.com/1767053 with 2 ERRORs
And network errors here Hardenize Report: lern2code.com
and it is showing DNS Zone errors that the Name Servers are not Operational.
You also an infinite redirect loop here
$ curl -k -Ii https://lern2code.com/.well-known/acme-challenge/sometestfile
Date: Fri, 12 Jan 2024 00:31:07 GMT
Server: Apache/2.4.52 (Ubuntu)
Location: https://lern2code.com/.well-known/acme-challenge/sometestfile
If you are looking for reasons why your DNS is wrong look here
https://dnsviz.net/d/lern2code.com/dnssec/
The Warnings are a likely reason for the Errors shown and the earlier query timeouts. Fixing those are a great start at least.
Thanks for your help. I found and fixed the problem.
The problem was that years old DNS addresses for my name servers were configured at my taurus.com domain registrar (network solutions.com). I updated the addresses and that appears to have fixed everything.
Hi @Torp,
Just so you know the issued certificate that is being served is crt.sh | 11786813177 does not have www.lern2code.com in the SANs. So lern2code.com is covered by the issued certificate, but www.lern2code.com is NOT covered.
covered - https://decoder.link/sslchecker/lern2code.com/443
NOT covered - https://decoder.link/sslchecker/www.lern2code.com/443
And www.lern2code.com is a CNAME to lern2code.com
Hi Bruce,
I noticed this problem yesterday, but I don’t know what to do about it. I do want a certificate for www.lern2code.com. Any pointers you can give would be appreciated.
Thanks,
Torp
You first need to have the www subdomain in your Apache VirtualHost. I assume it is not there because otherwise your certbot command would have included it.
Use the Apache ServerAlias statement to include the www subdomain in your VirtualHost for port 80 and port 443. Then, this command should add it to your cert
sudo certbot --apache --cert-name lern2code.com -d lern2code.com -d www.lern2code.com
If you need help with that please start by showing output of these commands
sudo apache2ctl -t -D DUMP_VHOSTS
sudo certbot certificates
Hi Mike,
I finally got to this and got it working.
Torp
