Hi All,
I seem to be successfully creating a Let’s Encrypt certificate for my domain, but I can’t find where the certificate is.
I need to get the pfx file, but can’t find it anywhere on my server. After reading a number of posts here, many seem to get asked what folder to write the certificate to, but I didn’t see anything like that.
I have looked inside the Certificate manager, and it’s are not in there anywhere.
I am using wacs.exe version 2.1.0.539
Any ideas would be greatly received. Thanks.
Cheers,
Paul
My domain is: pcapps.one and I’m trying to create a certificate for a sub-domain : tennispro.pcapps.one
I ran this command: wacs.exe
Options used
M: Create new certificate (full options)
4: Manual input
(to accept default friendly name)
2: [http-01] Serve verification files from memory (recommended)
2: RSA key
3: Windows Certificate Store
3: No additional storage steps required
4: Do not run any (extra) installation steps
[WARN] First chance error calling intoACME server, retrying with new nonce…
[INFO] Authorize identifier: tennispro.pcapps.one
[INFO] Authorizing: tennispro.pcapps.one using http-01 validation (SelfHosting)
[INFO] Authorization result: valid
[INFO] Requesting Certificate [Manual] tennispro.pcapps.one
[INFO] Store with CertificateStore…
[INFO] Installing certificate in the certificate store
[INFO] Adding certificate [Manual] tennispro.pcapps.one 2020/2/10 11:32:15 to store WebHosting
[INFO] Installing with None…
[INFO] Scheduled task looks healthy
EWB Web Server (not using IIS or any of the other usual ones)
Windows Server 2016 Datacenter
Version 1607
OS Build 14393.3474
Contabo
Yes (assume this means command prompt)
I’m using a control panel to manage my site:
Plesk web admin edition
