hi everybody. i take letsencrypt certificate on 08.07.2019. and on 06.10.2019 this certificate will be expired. pls help me to renew it! what i should do for it? which commands i should right on terminal?
domain name: ko.ksc.uz, osago.ksc.uz, m.ksc.uz
nginx on centos 7
Hi @johnmclane
how did you create these certificates? Do that again. And share your configuration.
PS: Checked one of your domains - https://check-your-website.server-daten.de/?q=ko.ksc.uz#ct-logs
There are a lot of older Letsencrypt certificates.
First from
2017-09-15 10:32:00
12 complete.
So you should know how you have created these certificates.
yes, i’m a new system administrator. i’ve never use let’s encrypt to take ssl certificate. former administrator don’t want to explain me how he do it. that’s why i need your help bro!
my domain ksc.uz
web server: nginx
OS: centos 7
i can login to a root shell on my machine
i don’t use a control panel to manage my site
Try running
sudo certbot certificates
to see if this machine uses Certbot.
You could also look at the shell history with the history command to see if there are commands visible that reveal more about what the previous administrator did.
Then start with some basics:
You have to use a client:
So: A lot of older certificates -> there should be an installed client, perhaps already with a working cron job.
Try
sudo ./certbot
or
sudo ./certbot-auto
sudo ./letsencrypt
sudo ./letsencrypt-auto
Or more generally, perhaps locate certbot-auto.
